That scenario is definitely a ground loop
Hi. Over the last few months i’ve managed to reduce the amount of this digital noise on my Seed based circuit by trying out lots of the methods suggested on this thread - including using a PDS1-S5-S5-D Isolator and lot’s of decoupling capacitors.
The noise now only occurs on the left channel of the audio output, the right channel is completely clean.
I wanted to ask about the software solutions that are mentioned on this thread:
- @kshep - moving LED function from main loop to AudioCallback
- changing the block size by dividing up code
My problem here is that I’m using Pure Data and pd2dsy so I don’t think I’m able to have this kind of control over the code - does anyone know if there is a way?
Thanks
Just thought I’d throw my experience into the pile here as I’ve had some decent success with only software refinements and no change to my audio callback.
The specific noise issue for me has been the high pitch whine at the frequency of (sample rate / audio block size) - in my case (48k / 8 = 6kHz).
I had about 5 different functions, within my main loop, that use pow(), and I swapped these out for either explicit multiplication (x squared becomes x*x) or if the exponent was a variable, I created a precomputed array of values and accessed those. This obviously only works when you have a limited amount of exponent choices… if your exponent is a float within a large range, that won’t likely increase efficiency.
Just doing that lowered my high pitch whine by ~15db. I’m fairly new to C++, but apparently the pow() function for smaller exponents, especially int exponents, is less efficient than explicit multiplication, and of course less efficient than precomputed values.
Mind you, I’m running a fairly jam packed project, so those may have simply been pushing me over the edge… your mileage may vary.
All this to say, if you’ve got a lot of math happening in your primary loop like I do, it’s worth a look to see if you can unload some of that processing power.
I’ve had a major development in my 6kHz (48kHz / block size 8) whiney noise issues. I have zero whine, and it was a result of a very simple change to my circuit ground path.
tl;dr; The change that solved my noise issue, was placing a jumper cable from DGND to as close to AGND as possible. Explanation below:
I’m a novice to circuit design / DIY electronics, so bear with me if this is simple stuff. I built my circuit on a breadboard and then, to make it more permanent, recreated the circuit on a “solder breadboard” - a prototype board with + / - rails and two disconnected sides. I mention this because it gives you an idea what the ground plane looks like.
I had the Daisy across the center. Digital ground to the left and analogue ground to the right, then the two ground rails bridged at the top of the board.
The change that solved my noise issue, was disconnecting DGND from the left rail, and instead placing a jumper cable from DGND to directly adjacent AGND.
I presume this means that the distance the ground points were traveling in the initial circuit, was long enough that it was able to soak up noise along the way.
I discovered this while trying to address noise I picked up from a new midi circuit I was adding - every individual midi signal came through the audio out as a “click”. In that case, I had to bring the ground for my midi circuit very close to AGND as well.
Again, I presume these issues are exacerbated by the limitations of the breadboard style design… but I can see how the same principle would apply to a custom PCB. Hopefully this gives hope or help to someone ![]()
hi - I was wondering: has it been established that the power management strategy can not be altered so that this ground ripple does not occur in the first place?
Here is a working backup link:
https://sebiik.github.io/community.axoloti.com.backup/t/connecting-audio-output-to-an-amp-with-shared-power-supply-same-ground/3785.html
I’ve been able to greatly reduce the whine by making a Ground Loop Break (GLB) circuit as used in the Axoloti and described in the forum post above, and the application note it refers to: https://www.ti.com/lit/an/sloa143/sloa143.pdf
I used an off-the-shelf TPA6132 board similar to the one @SmashedTransistors used; what was necessary was to break the SGND-GND connection on it, and use the SGND separately as described in the note.
The circuit can also be seen on page 4 of the Axoloti schematic:
If anyone knows of a (headphone) amp board that has a separate SGND connection already, that might be very handy.
I have to come back to this - it turns out my using of too thin breadboard wires was my original cause of whine to begin with. Apologies.
I guess I may have to be a little cautious still, but… it seems I’ve been able to solve the whine. It wasn’t just my breadboard wires, not sure how I came to that conclusion.
For me it was a question of not only having the SGND TPA6132 circuit at the output, but also (a highly simplified version of) the input wiring as in the Axoloti: using both the N and P inputs with one connected to ground (via one or two low value resistors), using a second TPA6132.
See the PDF I mentioned earlier. Sweet (almost, on breadboard) silence!
I am a new member on the forum and I have been reading posts about the noise from the analog outputs of Daisy Seed and how to get rid of it (cause I have the same problem).
My conclusion is that the voltage level to Daisy Seed’s pin 39 (VIN) should be as high as possible (in my case 16V) and the buffer size as low as possible (in my case 16), then the noise is virtually gone.
Why does 16v on Vin improve noise?
It would affect the duty cycle of the switching regulator, which could either make it better or worse.
In the several years I’ve followed discussions of noise here, I think this is the first time I’ve seen any mention of correlation with Vin.
@ArguZ, you say ground plane(s) and “special grounding and shielding planes”. This was years ago I know but I assume you made efforts to separate the AGND and DGND into seperate ground planes, connected a one spot. Any more than two big ground planes on that inside layer? How do you mean shielding more than a ground plane inbetween layers? Having noise problems on my first pcb and I would love to learn from your many, many iterations. I think there was a typo on “0 PCBs” how many was it actually
The input noise issue must be addressed at the hardware level first of course, but at some point this might be not enough for your needs.
To kill the remains of high-pitched noise caused by the audio callback current spikes, I found quite effective and computationally cheap to add in software a few 2nd-order notch filters (Q = 100, gain = -40 dB) tuned on the callback frequency and its first harmonics to process the inputs.
In combination with the solution I previously proposed on 2020-08-07 in this thread, this gives an excellent solution. Put the notch filters first, then the multi-band noise gate.
