You’ll still have to buffer data. Say you decomposed your processing function into 16 balanced sub-functions. The time can be divided in cycles of 16 samples:
Time 0 — the ADC provides the 16th sample (index 15) of a nearly full buffer, let’s call it A. Then you can start the processing calling function 0 on this 16-sample buffer. On the output, you’ll pass the sample at the index 1 of the previous output buffer, let’s call it B.
Time 1 — start filling a fresh input buffer (let’s call it C) with the input, index 0. Process the buffer A with function 1. Send index 2 of the buffer B to the DAC.
Time 2 — add the input to the buffer C, index 1. Process the buffer A with function 2, send buffer B index 3.
Time …
Time 14 — add the input to the buffer C, index 13. Process the buffer A with function 14, send the last sample of the buffer B, index 15.
Time 15 — add the input to the buffer C, index 14. Process the buffer A with function 15, and now it is ready for the output. Send index 0 of this buffer to the DAC.
Then repeat this cycle, rotating the buffers.
