Hello people!
I’m trying to add 2 channels of I/O on my Daisy Seed and just received my PCB using the PCM 3060 and after soldering + flashing the test code from libdaisy, I was not able to get any sound. I wasn’t sure if it’s a hardware or a software problem. Is there a way to tell if the Codec is functioning properly in VS Code?
Attached is my circuit based on the datasheet of DS.
I’m using this code to test if the codec is bypassing, only the builtin Codec works, but not the external PCM3060
/** Example of multichannel audio with two SAIs configured for
* i2s codecs
* This example is based on the seed2 DFM hardware.
* Both codecs are PCM3060
#include "daisy_seed.h"
/** This prevents us from having to type "daisy::" in front of a lot of things. */
/** Global Hardware access */
DaisySeed hw;
size_t size)
out[0][i] = in[0][i];
out[1][i] = in[1][i];
out[2][i] = in[2][i];
out[3][i] = in[3][i];
/** Initialize our hardware */
/** Configure the SAI2 peripheral for our secondary codec. */
SaiHandle external_sai_handle;
SaiHandle::Config external_sai_cfg;
external_sai_cfg.periph = SaiHandle::Config::Peripheral::SAI_2;
external_sai_cfg.sr = SaiHandle::Config::SampleRate::SAI_48KHZ;
external_sai_cfg.bit_depth = SaiHandle::Config::BitDepth::SAI_24BIT;
external_sai_cfg.a_sync = SaiHandle::Config::Sync::SLAVE;
external_sai_cfg.b_sync = SaiHandle::Config::Sync::MASTER;
external_sai_cfg.a_dir = SaiHandle::Config::Direction::TRANSMIT;
external_sai_cfg.b_dir = SaiHandle::Config::Direction::RECEIVE;
external_sai_cfg.pin_config.fs = seed::D27;
external_sai_cfg.pin_config.mclk = seed::D24;
external_sai_cfg.pin_config.sck = seed::D28;
external_sai_cfg.pin_config.sb = seed::D25;
external_sai_cfg.pin_config.sa = seed::D26;
/** Initialize the SAI new handle */
external_sai_handle.Init(external_sai_cfg);
/** Reconfigure Audio for two codecs
* Default eurorack circuit has an extra 6dB headroom
* so the 0.5 here makes it so that a -1 to 1 audio signal
* will correspond to a -5V to 5V (10Vpp) audio signal.
* Audio will clip at -2 to 2, and result 20Vpp output.
AudioHandle::Config audio_cfg;
audio_cfg.blocksize = 48;
audio_cfg.samplerate = SaiHandle::Config::SampleRate::SAI_48KHZ;
audio_cfg.postgain = 0.5f;
/** Initialize for two SAIs, including the built-in SAI that is
* configured during hw.Init()
hw.audio_handle.Init(audio_cfg, hw.AudioSaiHandle(), external_sai_handle);
/** Finally start the audio */
hw.StartAudio(AudioCallback);
/** Infinite Loop */
while(1) {}
Any advice is greatly appreciated! Thanksssss
