I hope that [data] is not updated at audio rate in this case! Not sure if there a way to prevent this for the CV-over-audio hack.
This is live! We have a new thread about the Max/MSP gen~ integration here!
hello, can we use Max for Live to create scripts for Daisy Patch?
@tsm
The code is exported from inside a [gen~] object.
Max For Live objects do not.
Only the contents of a [gen~] will be compiled.
The [Oopsy~] object wraps the code up for you
Oopsy on GitHub
[gen~] runs at sample speed, as opposed to Max, which runs… not at sample rate.
Unless you have intentional delays or [history~] objects in your [gen~] object, the code is executed in a single sample. This is not how Max, or Max For Live, works overall. Patching in [gen~] is a bit different than Max/M4L.
Check it out.
