To start, I want to emphasize that I have studied this thread extensively to try not to repost anything that has already been said. I have also followed this wiki to make sure I am doing things right.
I have a single Daisy Seed on a breadboard, plugged into my 2018 Macbook Pro and am trying to code it using Gen~ in MAX/MSP. I have run a ground wire from Analog Ground pin to the Digital Ground pin. I have a simple switch with Digital V Out going into the middle pin of the switch, and another pin going out from one side of the switch and into the Seed’s [ADC 3][A3/D18][25] pin with the intention of that pin reading an input of HIGH or LOW depending on the switch. I have no resistors on my breadboard.
In MAX I have the Oopsy object and a gen~ object. Into the gen~ I have MAX’s drumloop.wav playing constantly into IN 2 in the gen~ object. Inside gen~ I have [param sw1 @min 0 @max 1] going into the left input of a [gate] object. The right input of the [gate] object is being fed the drumloop.wav audio from outside the gen~ object. Then I have [gate] flowing into OUT 1.
I’m really sorry to hear that it’s been frustrating. I’ll do my best to help out!
Here are some thoughts to get us started
Were you able to get sound out of your Seed? A simple patcher that’s just a sine-tone at 440 hz.
I think you do need a pull-up resistor when using a switch.
Also, I think you should use the digital pins for the switch (look, I used to use ADC for buttons and switches too in the past, so I fully understand)
Are there any other lines in that JSON file?
Finally, let’s start simple! I suggest getting the analog knob reading to work. Let’s twist a knob and change a pitch of a sine-tone. And then let’s move on to switches and audio file playback.
8 Months later and I’ve decided to come back to this topic. I delayed responding mostly because you were putting out great videos on your Youtube channel as well as great stuff on Electrosmith’s channel and I was going to be patient for a video to cover this topic… but it looks like it isn’t going to be covered via YouTube anytime soon.
Never got any sound out!
I will breadboard it again with a pullup resistor to verify. But I am unsure this will resolve the issue, since I couldn’t even get a switch to close a circuit for a pin to send data into Max MSP (just a 1 or 0 input)
I will try that!
There are no other lines in the JSON file, do I need to add more/something else?
I would love to get a knob to work. I will try the changes above and see if it gets a knob to work… what should I do if it doesn’t work?
Thanks for all your help and amazing tutorials online. I hope you are able to make more.
Can you explain why it’s the case that external pull-up resistors aren’t needed for Oopsy/Gen patches that use switches? Is this because selecting the “switch” component in the JSON enables an internal pull-up on the Daisy? And if so, do we get the same behavior on the Seed2 DFM?
I’m about to order some PCBs to mate with the DFM but hesitating since I’m not sure if I need to add external pull-ups. I guess it wouldn’t do any harm…
Yes! Internal pull-up resistor can be used for the switch component.
It should be on as default (for both Seed and Seed2 DFM) when you configure "Switch" in the json but you can of course turn it off if your circuit has external pull up resistor.
You can include "pull": "daisy::Switch::PULL_NONE" to turn it off
