When I did this, nothing happened. I am wondering if I missed a step in here… I just wasn’t sure.
Also: Is there a difference between CTRL + P and CTRL + SHIFT + P as it looks like two different keyboard shortcuts are referenced in this part of the documentation.
The system that I am using the dev work is brand new
When I went through the steps initially in VS Code I did not have the c/c++ extensions installed (I added them later)
(not sure if this was needed) but I did a full reboot because I had setup the driver for the USB debugging and that seemed to “install” a driver
upon reboot and having the c++ extensions installed in VS Code seemed to allow the command to work.
Note: Before when I went to type in the command nothing was highlighted and no options were showing up as I was typing… thus, I suspect having the c++ extension installed was the core of the reason why this was not working for meat the time.
Very interesting. There’s a slight difference between command p and command shift p. They’re the same field, but one of them auto populates with a > to run commands, which I believe includes tasks.
There’s some more info here.
With regards to the C / C++ extension, we should definitely add that to the install instructions! Can’t confirm / deny if that would mess with the tasks command but it’s still quite necessary if you’re going to be writing cpp.
