Hi, I have a motion sensor, the “Sharp 2Y0A21”, and I would like to connect it to the daisyseed (to then manage a parameter of a patch in plug data). This sensor operates with a voltage of 5V, how do I connect it to a daisy ADC?
I recommend checking out this thread
I linked to a video that shows you how to connect a potentiometer to the Daisy and you can apply the info in that tutorial to that particular distance sensor.
Let us know how it goes ![]()
I missed this answer. The sensor doesn’t provide great feedback because it’s supposed to be powered by 5 volts. I’ve seen other sensors like the RCWL-1601 or the US-100 (from Adafruit) that only require a 3 volt power supply, but I don’t know how to connect them or how to compile the json file to use them in plug data in this case.
