The one that is labeled USER should be flashing periodically when you receive it. The other LED labeled PWR should be illuminated whenever the Daisy Seed is powered.
This is not true for the daisy pod. The default pod program has the two tricolor pod LEDs turning on, but never the USER LED.
For me, this made some of the daisy setup instructions very confusing. (“wait for USER to stop flashing? it never started and never has???”)
For anyone having this issue on Windows, I believe a recent OS update has rendered our instructions partially incorrect.
As far as I can tell this started when Windows updated, but I am unable to get the Daisy to show up in any WebUSB application while it is using the libusb driver.
Fortunately, swapping to WinUSB seems to work totally fine for both the Web Programmer and the dfu-util cli.
EDIT: Never mind, bad cable. I switched to a different cable and it’s working fine now.
Hi, I’m having the same issue. Windows 10, Chrome version 86.
I have tried running Zadig, but the device doesn’t show up in the list. In fact, the device doesn’t show up in the Device Manager at all. I’m pretty sure that the USB cable I’m using can carry data, as it came with my Raspberry Pi. Is there a compatible driver for Windows that I can download?
Hello, I have a question. When flashing in Zadig I select “DFU in FS Mode”. Under Drive there is (NONE) with → WinUSB (v6.1 …). Is this DRIVER field supposed to be empty? I cannot edit it or anything. Unsure how to proceed.
That is correct.
All that matters is that you’re selecting WinUSB as the destination driver on the right hand side.
Make sure the you press the “replace driver” button.
And just to be clear, Zadig is not for flashing firmware, just for resetting your driver.
And it is only applicable if you are on Windows.
