DaisySP now has a CMakeLists.txt file allowing for builds to be generated on multiple platforms a bit easier.
For now the ARM build for the actual Daisy hardware will still be done with the local Makefile, but if you’ve been interested in using the DSP in DaisySP away from the Daisy hardware this should make that a little bit easier.
I, personally, am fairly new to CMake so any feedback is welcome.
As a first-pass test we’ve also added an example using JUCE. A simple plugin based on one of the examples that uses DaisySP for the synthesis, has a slider in the GUI, and accepts MIDI input.
So far, I have only tested the standalone target on Windows, but will be testing elsewhere and improving the example over the next few weeks.
Apart from being able to use the DSP in other integrations, this also opens the door to easier debugging/development of DSP modules, as well a road toward better CI with actual tests for each module, etc.
Hi! I came across this post a while ago but couldn’t get into it untill now.
I love that you are working in this because for my masters thesis I’m trying to make both a pedal (using Daisy Seed) and a plugin (using Juce) with the same effect and try to make them as similar as possible to each other, so being able to use the same DaisySP functionality in both is just what I need
I’ve been following the steps from your GitHub link but i get this error:
In the DaisySP folder from your GitHub link there’s no CMakeLists.txt so I tried copying the one from the DaisySP folder in the DaisyExamples GitHub site and then I get this other error:
Neat - so I tried it out - it works on Linux after a couple of updates:
DaisySP was missing CMakeLists.txt in the version included in Daisy-JUCE-Example so I moved to master. @RatherBeAlex - I think this is the same as your problem:
Daisy-JUCE-Example/plugin/DaisySP$ git status
HEAD detached at 08f280c
nothing to commit, working tree clean
Daisy-JUCE-Example/plugin/DaisySP$ git checkout master
Previous HEAD position was 08f280c Update README.md
Switched to branch 'master'
Your branch is up to date with 'origin/master'.
And then had to update PluginProcessor.h to point to DaisySP/Source/daisysp.h
Daisy-JUCE-Example/plugin/source/PluginProcessor.h:4:10: fatal error: ../DaisySP/daisysp.h: No such file or directory
4 | #include "../DaisySP/daisysp.h"
After that a simple make worked fine.
I could bring up the Stand alone app - sound was kind of chunky, but I messed around with the audio settings and changed the buffer size and it mostly sounds better.
Oh hey! Thanks for trying it out! Sorry it didn’t work right away.
The reference for DaisySP is certainly out of date, and can be updated to master. (I’ll push that fix the next time I open up the project).
Sound settings are probably pretty system dependent, I don’t remember what they’re set to, but the PC I was running it on had an audio interface and is pretty fast. So I may have had some of the buffer sizes pretty low. I can update them to be a bit more conservative for (hopefully) a better first impression to other folks trying it out.
If there’s anything specific you would like to see added or any other issues feel free to let me know, and I’ll see about fixing it up!
I’m suuuch a noob so I would have never got to to solve this on my own. I’m not sure what moving to master means so I’ll try to look for some info to understand it.
Anyway, that worked out well:
Then I pointed PluginProcessor.h to daisysp.h changing this:
#include “…/DaisySP/daisysp.h”
to this:
#include “daisysp.h”
I hope it isn’t something too stupid All the errors on the code went away but in the end, after compiling lots of .cpp’s, I get something like the following (may not be exact since I translated it from Spanish):
3>C:\Users\Alex\Daisy-JUCE-Example\plugin\DaisySP\Source\Utility/dsp.h(210,23): error C2290: C++ ‘asm’ sintax has been omited. Use __asm. (compiling origin file C:\Users\Alex\Daisy-JUCE-Example\plugin\source\PluginEditor.cpp)
And some other warnings too.
Is this because I didn’t point PluginProcessor.h correctly to daisysp.h or there may be something else I could have done wrong?
Hope someone can help me again, if not thanks anyway and I’ll try to figure out something to make it work.
Ah, okay! So some of the changes to DaisySP, and its cmake build definitely had an effect. I’ve just pushed a tiny update that fixes the path as you pointed out above:
A part from that you can do the following few things and everything should build (though you’ll probably still have some warnings).
grab the latest DaisySP by navigating to plugin/DaisySP and running: git checkout master && git pull
I got the same error for using asm("bkpt 255") in the dsp.h file, which I will patch in DaisySP soon, but for now you can just comment it out (line 210 of dsp.h)
I have 16 total warnings after those changes, but the project builds and runs as expected.
Hope that helps, and I’ll try to get the asm error fixed in DaisySP asap.
With that I was able to try the standalone plug-in test
I could just try it right now but I’ll get into the code ASAP and see how this can work for my project. It really looks like this is going to be very very helpful.
Thank you very much for getting this ready and for your help!
It looks like we didn’t get a chance to properly test it with OSX since posting this, so we can’t guarantee that it’ll work for you. I’m sorry about that.
though i have been able to get other peoples NON-DaisySP JUCE CMAKE examples to compile and run without issue on OSX --this Daisy Sp JUCE example repo gives me nothing but an empty plugin when I finally am able to get it to compile (it compiles with errors coming from DaisySp).
the odd issue is that if i follow the directions exactly as on the github, the recurse module of DaisySp it gives me includes no Cmake.Lists file (possibly it points to an old version?) and will not compile due to that issue.
as it does not note which version of DaisySp it wants i simply tried replacing this DaisySp with the current folder–when I did that it would finally run Cmake and compile BUT all it put out was empty plugins folder and .plist files
this seems like it would be a good thing to get working so that DaisySP could be used by more and more people and hence have more connection to the Daisy.
This is a very interesting project.
I followed the above steps and successfully cmake it.
However, there is no binary file anywhere in the builid directory
Where was the output?
I have changed the path of the header file.
in windows 10(git bash result)
$ cmake ..
-- Building for: Visual Studio 17 2022
-- Selecting Windows SDK version 10.0.22621.0 to target Windows 10.0.19045.
-- The C compiler identification is MSVC 19.37.32824.0
-- The CXX compiler identification is MSVC 19.37.32824.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring juceaide
-- Building juceaide
-- Exporting juceaide
-- Configuring done (13.3s)
-- Generating done (0.4s)
-- Build files have been written to: C:/Users/****/daisy/Daisy-JUCE-Example/plugin/build
cmake --build .
Do I need to do cmake --build ?
I got this error.
cmake --build .
MSBuild version 17.7.2+d6990bcfa (.NET Framework)
Checking File Globs
adsr.cpp
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\DaisySP\Source\Control\adsr.cpp(86,44): error C2065: 'M_E': undefined identifier. [C:\UsersShiro
Yuki\daisy\Daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj]
C:\Users\hiroyuki\daisy\daisy-JUCE-Example\plugin\DaisySP\Source\Control\adsr.cpp(86,25): error C2737: 'target': initializing const object
You need to initialize the const object
[C:\Users\hiroyuki\daisy\daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj]
phasor.cpp
ladder.cpp
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\DaisySP\Source\Filters\ladder.cpp(94,16): error C3861: 'optimize': identifier not found
C:\Use
rs\hiroyuki\daisy\Daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj]
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\DaisySP\Source\Filters\ladder.cpp(94,41): error C4430: no type specifier - assumed int
assumed to be int. Note: C++ does not support
Note: C++ does not support int as default value [C:\Users\hiroyuki\daisy\daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj].
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\DaisySP\Source\Filters\ladder.cpp(94,43): error C2062: type 'void' is not needed. [C:\Users
C:\daisy\Daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj]
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\DaisySP\Source\Filters\ladder.cpp(96,1): error C2143: Syntax error: ';' is before '{'.
C2143: Syntax error: ';' is not before '{'. [C:\User
C:\Users\hiroyuki\daisy\Daisy-JUCE-Example\plugin\build\DaisySP\DaisySP.vcxproj]
To get this running I had to use the current DaisySP and JUCE. I just downloaded and replaced them. Replaced the path in PluginProcessor.h .
Do the cmake …
And after that did a make. That worked for me on Linux and everything got compiled and was usable.
i hope this is the right place to ask: is there some way to run daisysp without juce on macos or linux? i’m thinking portaudio or directly porting into sox/ffmpeg. i’d like to work with the library directly, without bothering with another library.. any pointers would be appreciated so far i’m trying to figure out how to play a simple sine wave through portaudio.. i can also open a new thread if that’s better.
