I’m still having a hard time implementing this. I tried starting with a clean slate, so I grabbed the example code from DaisyExamples/pod/SynthVoice. It uses the mode variable to determine what params are set to the knobs, but even this example code still suffers from the original problem of keeping the value of the knob untouched when traversing through modes. ie, if i go to mode 2, change a value on a knob, and then go back to mode 1, whatever the changes i made on the knobs in mode 2 translate to mode 1 because of the placement of the knobs changed in mode 2.
#include "daisysp.h"
#include "daisy_pod.h"
static DaisyPod pod;
static Oscillator osc, lfo;
static MoogLadder flt;
static AdEnv ad;
static Parameter pitchParam, cutoffParam, lfoParam;
int wave, mode;
float vibrato, oscFreq, lfoFreq, lfoAmp, attack, release, cutoff;
float oldk1, oldk2, k1, k2;
bool selfCycle;
void ConditionalParameter(float oldVal,
float newVal,
float ¶m,
float update);
void Controls();
void NextSamples(float &sig)
float ad_out = ad.Process();
vibrato = lfo.Process();
osc.SetFreq(oscFreq + vibrato);
sig = osc.Process();
sig = flt.Process(sig);
sig *= ad_out;
size_t size)
Controls();
float sig;
NextSamples(sig);
// left out
out[i] = sig;
// right out
out[i + 1] = sig;
// Set global variables
float sample_rate;
mode = 0;
vibrato = 0.0f;
oscFreq = 1000.0f;
oldk1 = oldk2 = 0;
k1 = k2 = 0;
attack = .01f;
release = .2f;
cutoff = 10000;
lfoAmp = 1.0f;
lfoFreq = 0.1f;
selfCycle = false;
//Init everything
pod.Init();
sample_rate = pod.AudioSampleRate();
osc.Init(sample_rate);
flt.Init(sample_rate);
ad.Init(sample_rate);
lfo.Init(sample_rate);
//Set filter parameters
flt.SetFreq(10000);
flt.SetRes(0.8);
osc.SetWaveform(osc.WAVE_SAW);
wave = osc.WAVE_SAW;
osc.SetFreq(440);
osc.SetAmp(1);
// Set parameters for lfo
lfo.SetWaveform(osc.WAVE_SIN);
lfo.SetFreq(0.1);
lfo.SetAmp(1);
//Set envelope parameters
ad.SetTime(ADENV_SEG_ATTACK, 0.01);
ad.SetTime(ADENV_SEG_DECAY, .2);
ad.SetMax(1);
ad.SetMin(0);
ad.SetCurve(0.5);
//set parameter parameters
cutoffParam.Init(pod.knob1, 100, 20000, cutoffParam.LOGARITHMIC);
pitchParam.Init(pod.knob2, 50, 5000, pitchParam.LOGARITHMIC);
lfoParam.Init(pod.knob1, 0.25, 1000, lfoParam.LOGARITHMIC);
// start callback
pod.StartAdc();
pod.StartAudio(AudioCallback);
while(1) {}
//Updates values if knob had changed
float newVal,
float ¶m,
float update)
if(abs(oldVal - newVal) > 0.00005)
param = update;
//Controls Helpers
void UpdateEncoder()
wave += pod.encoder.RisingEdge();
wave %= osc.WAVE_POLYBLEP_TRI;
//skip ramp since it sounds like saw
if(wave == 3)
wave = 4;
osc.SetWaveform(wave);
mode += pod.encoder.Increment();
mode = (mode % 3 + 3) % 3;
void UpdateKnobs()
k1 = pod.knob1.Process();
k2 = pod.knob2.Process();
switch(mode)
case 0:
ConditionalParameter(oldk1, k1, cutoff, cutoffParam.Process());
ConditionalParameter(oldk2, k2, oscFreq, pitchParam.Process());
flt.SetFreq(cutoff);
break;
case 1:
ConditionalParameter(oldk1, k1, attack, pod.knob1.Process());
ConditionalParameter(oldk2, k2, release, pod.knob2.Process());
ad.SetTime(ADENV_SEG_ATTACK, attack);
ad.SetTime(ADENV_SEG_DECAY, release);
break;
case 2:
ConditionalParameter(oldk1, k1, lfoFreq, lfoParam.Process());
ConditionalParameter(oldk2, k2, lfoAmp, pod.knob2.Process());
lfo.SetFreq(lfoFreq);
lfo.SetAmp(lfoAmp * 100);
default: break;
void UpdateLeds()
pod.led1.Set(mode == 2, mode == 1, mode == 0);
pod.led2.Set(0, selfCycle, selfCycle);
oldk1 = k1;
oldk2 = k2;
pod.UpdateLeds();
void UpdateButtons()
if(pod.button1.RisingEdge() || (selfCycle && !ad.IsRunning()))
ad.Trigger();
if(pod.button2.RisingEdge())
selfCycle = !selfCycle;
void Controls()
pod.ProcessAnalogControls();
pod.ProcessDigitalControls();
UpdateEncoder();
UpdateKnobs();
UpdateLeds();
UpdateButtons();
The switch being here:
void UpdateKnobs()
switch(mode)
case 0:
break;
case 1:
break;
case 2:
default: break;
using this function here:
float newVal,
float ¶m,
float update)
param = update;
And I’m just confused. Feel like the original author’s intent with the ConditionalParameter function was to preserve the previous state of the knobs when traversing modes so that your “patch” doesn’t change every time you switch a mode. But when flashing this code onto the daisy pod, it still suffers from the the parameters changing every time a mode is changed.
If you can point me in the right direction, even with just some general pseudocode, it would be immensely appreciated. I’ve looked all over the internet attempting to find a resolution with no luck. And honestly it’s a very good implementation to know just because no matter how limited you are with your inputs, as long as you have one button, and one knob, theoretically you can treat it as a parameter input for as many parameters as you’d like. IE Pamela’s New Workout, contains an entire plethora of menus you can traverse literally just using one rotary encoder.
