Thank you Takumi- it’s nice to meet you.
I am using oopsy.patch_sm in Max to program the Daisy Submodule using gen~, for a custom module I developed. I have no problems accessing cv1-9 with param declarations in gen~, but would like to have four more potentiometers using the adc_9 - 12 pins.
I looked at the json file and am not sure where to add the code you suggested. Even so, how would I upload a custom json file to the Daisy since it’s likely that oopsy would rewrite a new json every time it is flashed in Max?
Thanks again for your help. Copied below is my json file for a cycle controlled by [param adc_9 @min 50 @max 1000] and sent to out1.
"class": "Module",
"id": "node_2357",
"inlets": {
"outlets": [
"assist": "out1"
"imports": {
"functions": {
"block": {
"class": "Block",
"id": "node_2372",
"children": [
"class": "Declaration",
"id": "node_2359",
"name": "adc_9",
"inputs": [
"class": "Constant",
"id": "node_2360",
"value": "0",
"eval": 0,
"type": "constant int",
"source": "box: [param adc_9 0 @max 1000 @min 50] => adc_9"
"attributes": {
"max": {
"class": "Attribute",
"id": "node_2361",
"name": "max",
"value": {
"id": "node_2330",
"value": "1000",
"eval": 1000,
"source": "1:19 -> 1:23"
"min": {
"id": "node_2362",
"name": "min",
"value": {
"id": "node_2332",
"value": "50",
"eval": 50,
"source": "1:29 -> 1:31"
"type": "control t_sample",
"typename": "Param",
"class": "Statement",
"id": "node_2363",
"inputs": [
"class": "Expression",
"id": "node_2364",
"operator": "cycle",
"inputs": [
"class": "Variable",
"id": "node_2365",
"name": "adc_9",
"source": "box: [cycle $in1] => cycle_48,cycleindex_49"
"attributes": {
"type": "signal t_sample",
"outputs": [
"id": "node_2366",
"name": "cycle_48",
"id": "node_2367",
"name": "cycleindex_49",
"id": "node_2368",
"inputs": [
"id": "node_2369",
"name": "cycle_48",
"source": "box: [out 1 $in1] => "
"outputs": [
"id": "node_2370",
"name": "out1",
"source": "patcher: gen.patcher 0x1216fcfc0 graph 0x600000b57570"
