Windows 10 - JTAG - Error: open failed
Although everything setup fine and ST-Link updated to latest firmware, I just cannot have it connect
  • I provide 4.8V from a lab power supply to the daisy, it turns on and blink, so my previous soft is running
  • the device is recognized in the Device manager
I get that error when I run make program from VSCode command line
$ make program
openocd -s /usr/local/share/openocd/scripts -f interface/stlink.cfg -f target/stm32h7x.cfg \
        -c "program ./build/MyProject.elf verify reset exit"
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.11.0-00155-ge392e485e (2021-03-15-16:44)
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1800 kHz
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
make: *** [../DaisyExamples/libDaisy/core/Makefile:318: program] Error 1
I tried downloading this
Download xpack-openocd-0.12.0-2-win32-x64.zip (openocd-xpack) (sourceforge.net)
but I don’t know what to do with them, no installer, just exe/dll files
am I missing something ?
anyone ? that’s a lot of investment so far
should I return the dongle ? the daisy seed runs fine
I would gladly help you, but you need to switch to Linux :slight_smile:
On an more serious note, you need openocd 0.12. IME sourceforge has been dead for quite some time, but there maybe some binaries on github.
https://openocd.org/pages/about.html
ok but how VSCode knows where to find the executable ? makefile ? path ? env variable ? c:\windows ? project folder ?
in the folder where I run the command
  • I copied exe/dll
  • I copied the scripts folder from the archive
  • I copied both cfg files
I get Debug Adapter has to be specified
$ ./openocd.exe   -c "program ./build/MyProcessor.elf verify reset exit" -f ./ocd/interface/stlink.cfg -f ./ocd/target/stm32h7x.cfg -s ./ocd
xPack Open On-Chip Debugger 0.12.0+dev-01312-g18281b0c4-dirty (2023-09-04-22:32)
Error: Debug Adapter has to be specified, see "adapter driver" command
ok apparently the order of parameters matter
$ ./openocd.exe -f ./ocd/interface/stlink.cfg -f ./ocd/target/stm32h7x.cfg -s ./ocd  -c "program ./build/MyProject.elf verify reset exit"
Info : STLINK V3J14M5 (API v3) VID:PID 0483:3754
Info : Target voltage: 3.007210
Info : [stm32h7x.cpu0] Cortex-M7 r1p1 processor detected
Info : [stm32h7x.cpu0] target has 8 breakpoints, 4 watchpoints
[stm32h7x.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000638 msp: 0x20020000
Info : Unable to match requested speed 4000 kHz, using 3300 kHz
** Programming Started **
Info : Device: STM32H74x/75x
Info : flash size probed value 128k
Info : STM32H7 flash has a single bank
Info : Bank (0) size is 128 kb, base address is 0x08000000
Info : Padding image section 1 at 0x0801e408 with 24 bytes (bank write end alignment)
Warn : Adding extra erase range, 0x0801e420 .. 0x0801ffff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
thanks for your help man !!
