Web programmer not working with patch.init()
Note that this is the first product that I’m trying so I haven’t gotten this working with daisy seed or otherwise.
While I am able to get to a point where, after clicking ‘connect’, google chrome shows ‘DFU in FS mode- paired’, the program buttons remain greyed out even after I select a device type and binary to flash. Flash Blink! remains disabled.
Notably the ‘Connect’ button does not grey out as I would expect it to after making a connection. How do I work around this?
Currently using Ubuntu 18.04. I tried to connect with windows but the device didn’t even show up in the selections- at least I got as far as I did on linux.
Sorry to hear that! Are there any errors in the console? You can open it with F12 I’m gonna take some time to test the site on my Linux computer today for you.
Regarding the Windows issue, did you reset your USB driver with Zadig? If not, there’s instructions to do that here. Maybe the site will work there if we can’t get it working on Linux.
Okay, fixing the driver and flashing from windows has worked for me. Thanks- but let me know if you can get it working on linux too!
I’ve been using the ‘make program-dfu’ from linux and in the DaisyExamples folders. Using the CLI fits the linux workflow really nicely for me. Leaving this here just in case other linux users want an alternative.
Glad windows is working out for you!
I can confirm the site isn’t working on Linux, I’m looking into a fix now.
@ben_serge Hi there. Did this ever get fixed? I’m trying to set up a new Daisy seed via a Linux machine and am observing the same behavior (“Flash Blink!” and “Program” buttons remain grayed out after selecting DFU in FS mode).
I can confirm that it still doesn’t work on linux. Here’s the error in the console:
Error with Permissions-Policy header: Origin trial controlled feature not enabled: 'interest-cohort'.
However it works in vscode using the build_and_program_dfu task
There was another issue that was brought up recently about the Web Programmer, so we should revisit this Linux + SM problem also when we get a chance in the future. Thank you for the reminder.
I also can’t use the web programmer on Chromium on Linux.
(12th November 2024.)
I believe there are issues with Chromium and web USB. If you are able to, we recommend installing Chrome. Let us know if that works :slight_smile:
Are those issues reported anywhere? There shouldn’t be any specific difference between these two.
I use Chromium all the time for this purpose on Linux and it works just fine :person_shrugging:
Oh, then it works! I don’t have much experience with Linux so I appreciated your insight :man_bowing:
Hello,
I also experience problem with chromium and linux (it use to work in 2002, I did not try since).
lsusb see the daisy in DFU mode. chromium open a popup to select the device, then programming fail.
This also fail on the same way on Mac mini OS14.0 / Google Chrome version 141.0.7390.55 (not my computer) :
“Pressing FLASH on browser.
Pop up menu now display DFU in FS Mode.
The computer still can’t connect to Kagouyar. “
hello,
Could anyone test and report a working setup for both linux ans osX?
Thanks
