I am getting this error when I try to run ‘task build_all’ with the Blink.cpp file in VS Code.
this is the output in the Terminal:
> Executing task: make <
make: *** No targets specified and no makefile found. Stop.
The terminal process "zsh '-c', 'make'" failed to launch (exit code: 2).
Terminal will be reused by tasks, press any key to close it.
Really stuck, I followed the instruction on the wiki, toolchain is installed, latest VS Code, Java installed.
You’re probably in the wrong folder. In vscode choose File > Open Folder and pick the Blink folder.
You should be able to run the task successfully then.
It’s a bit of a weird setup but the DaisyExamples repo is a VS Code project, and each example is its own project as well. So to flash a specific example you need to open that project rather than the global one from the repo.
