Hello,
I ordered an Electro Smith Daisy Field and it should get in tomorrow. In preparation, I am trying to set up my development environment.
Context
I am a seasoned TypeScript
developer with zero experience in C++
I work on an M1 Mac.
I am very comfortable in the cli
I installed arm-none-eabi-gcc
using brew
as follows:
brew install armmbed/formulae/arm-none-eabi-gcc
Compiling Works
From the cli
I have successfully compiled both libraries (libDaisy
and DaisySP
) and two of the examples (field/KeyboardTest
and patch/PluckEcho
VS Code Configuration Warning
When I open VS Code, I get the following error in output of the C/C++ Configuration
Unable to resolve configuration with compilerPath
"/usr/local/bin/arm-none-eabi-g++".
Using "/usr/bin/clang" instead.
Note that VS Code is looking for arm-none-eabi-g++
in /usr/local
instead of /opt/homebrew
, which is the default for brew
/opt/homebrew/bin/arm-none-eabi-g++
Errors in VS Code
As you can see in the screenshot, the language server seems to have problems with some of the code:
PolyPluck is not a template C/C++(864)
identifier "ReverbSc" is undefined C/C++(20)
I assume that this might have to do with the failing configuration.
Am I missing anything obvious?
Hi all, we’ve made some changes to DaisySP that we’d like to share!
These have come together under the banner of DaisySP V1.0.0
TLDR: How does this affect me?
For standalone projects, one at a time, cd into libDaisy and DaisySP.
Run git pull --recurse-submodules then make . If you have a VS Code task set up to build the libraries, you can use that too once you’ve pulled the latest versions.
If you are using DaisyExamples, you should just run git pull --recurse-submodules on DaisyE…
This explains the ReverbSx error, possibly the other,too.
In short, add USE_DAISYSP_LGPL=1
to the Makefile.
@tele_player Thanks for your super quick reply!
Unfortunately this is not the root of my problems. At least, that is what I think…
I use the latest version of electro-smith/DaisyExamples
. As such, the Makefile
already contains the USE_DAISYSP_LGPL
constant:
TARGET = PluckEcho
USE_DAISYSP_LGPL = 1
# Sources
CPP_SOURCES = PluckEcho.cpp
As noted in the initial post, compiling in the cli
works perfectly. The problem I am trying to solve relates to VS Code
exclusively.
UPDATE
After changing the "compilerPath"
in .vscode/c_cpp_properties.json
as follows, the error regarding C/C++ Configuration
is gone:
"cStandard": "c11",
- "compilerPath": "/usr/local/bin/arm-none-eabi-g++",
+ "compilerPath": "/opt/homebrew/bin/arm-none-eabi-g++",
"cppStandard": "c++17",
This being said, the errors in the .cpp
files remian:
Did you try the Quick Fix suggestions?
@tele_player thanks for sticking with me. I am not entirely sure I understand what Quick Fix
suggestions you mean.
Adding #define USE_DAISYSP_LGPL 1
to the top of the cpp
file fixed the errors in VS Code
It is not satisfactory to have to define the makro in my file, given that others do not seem to need this.
It will do for now. My c++
skills are almost non-existant, so debugging this is not a task I am up to for now. Maybe in the future.
Look at your screen shot, it shows Quick Fix, which you click for a suggestion, but not necessarily the best solution.
Agreed, having to use a define in your source file is less desirable, but put a comment near it explaining it’s an imperfect workaround, and life goes on.
I normal just work with vi and command line, I find VS code setup confusing.
