Hi, I’m trying to coding a variable sample rate oscillator with Daisy.
I’ve a pre-compiled sine lookup table of 512 entry. A timer, which speed is regulated by a potentiometer, periodically trigger a function which pick up the new sine value and output it from the two internal 12bit DAC.
It works, but I can’t get it works for sine faster than 1.250 kHz ( timer speed 1.250 kHz * 512 = 640 kHz).
Is there a way to speed up the process?
#include "daisy_seed.h"
#include "daisysp.h"
#include <stdio.h>
#include <string.h>
using namespace daisy::seed;
DaisySeed hw;
TimerHandle tim2;
TimerHandle::Config tim_cfg;
///////////// Global ///////////////////
const uint16_t nSample = 512;
const uint16_t sampleLimit = (nSample - 1);// * 1024;
float sine[nSample+1];
float final[2];
void routineOutput(){
static int16_t I = 0;
for(int i = 0; i < 2; i++){
final[i] = sine[I] * 4000.f;
hw.dac.WriteValue(DacHandle::Channel::ONE, final[0]); // CV0
hw.dac.WriteValue(DacHandle::Channel::TWO, final[1]); // CV0
I++;
if (I >= sampleLimit ) { I = 0; }
void CallbackOut(void* data){ routineOutput(); }
float Step = TWOPI_F / nSample;
for (int a = 0; a < nSample; a++) {
sine[a] = sinf(Step * a);
sine[a] = ((sine[a]+1.f)/2.f);
sine[sampleLimit] = sine[0];
tim_cfg.periph = TimerHandle::Config::Peripheral::TIM_5;
tim_cfg.enable_irq = true;
tim_cfg.period = 500;
tim2.Init(tim_cfg);
tim2.SetCallback(CallbackOut);
tim2.Start();
hw.Configure();
const int num_adc_channels = 1;
AdcChannelConfig adc_config[num_adc_channels];
adc_config[0].InitSingle(A0);
hw.adc.Init(adc_config, num_adc_channels);
hw.adc.Start();
// init DAC outputs
DacHandle::Config cfg;
cfg.bitdepth = DacHandle::BitDepth::BITS_12;
cfg.buff_state = DacHandle::BufferState::ENABLED;
cfg.mode = DacHandle::Mode::POLLING;
cfg.chn = DacHandle::Channel::BOTH;
hw.dac.Init(cfg);
// Loop forever
for(;;)
uint32_t vOct = hw.adc.Get(0);
static uint32_t oldVOct;
if(oldVOct > vOct + 5 || oldVOct < vOct - 5 ){
oldVOct = vOct;
tim_cfg.period = vOct;
tim2.Init(tim_cfg);
