I am playing with daisysp outside daisy seed hardware and when I change the audio buffer size from 1 or 2 to 48, 96, or 192 I face issues of audio data getting corrupt.
As per my observation, this is because sample_rate basically changes. In this case the buffer is sampled at 48kHz at a length of 96. What’s the sample rate value that I should feed into daisysp library? Because 48000.0f does not work in that setup.
If I read it correctly, the original post refers to using DaisySP without using Daisy. So anything about how to set blocksize and sample rate are not relevant.
To the original poster - what specific DaisySP objects are you trying to use? Generally, block size isn’t even known in DaisySP; processing functions are called once per sample, and are unaffected by block size.
