USB Ground loops and noise
Hi people :waving_hand:
I need some opinions!
We are in the late stages of developing our product.
Right now we have 10 units out in the wild being used by live musicians and studio musicians.
Everything has been going very well and we are getting a lot of good feedback, however 1 tester has a problem.
They are getting strange background noise/interference when using a particular power adapter.
Our device is USB powered.
After testing a bunch of different power adapters and power extension combinations i am able to reproduce it with 1 particular adapter.
I understand that this is something to do with a ground loop or a noisy adapter.
I did so reading and apparently there are components that i can add to the USB power input on our PCB that will filter/clean the incoming signal.
My question is this: Can i really design our PCB in such a way that we avoid all external ground loop and noisy power issues? And if so, is it necessary or is it normal to just tell people that they need to use a power setup that is not noisy?
Many thanks for all your input and sugestions!
A little more context: the noise is more than the usual noisy USB background noise, itโ€™s actually in sync with things happening on the board, like pwm and I2C signals. Normally the board is very quiet and works perfectly, itโ€™s just with certain power supplies that the noise is audible :man_shrugging:
I donโ€™t have any suggestions, but I could understand your setup better.
Is power being supplied over USB into the USB jack on the Seed, or is it going into the Vin pin?
Are the AGND and DGND connected, as required?
USB power supplied over VIN and the grounding setup on the PCB is correct and works perfectly with 90% of power supplies.
Is noise on the Vin pin (with the bad power supply) dropping the voltage below the 5V minimum?
i finally got to meet with the tester and he showed me his setup. The usb cable he was using was the thinnest cheapest looking one i have ever seen :smiley:
So i gave him one of my spares and the issue went away.
Perhaps you where right about it not supplying enough voltage.
Perhaps it was designed to charge a disposable vape or something like that and they just used the cheapest possible.
Anyway, thanks for the suggestion!
Ah yes, that explains it. the USB cable itself can be a major culprit.
one thing i have had success with in other designs with power supply noise is a ferrite bead in series with the incoming supply. along with my standard 47ohm/100u/100n combination seems to eliminate the whine that can come from bad supplies. worth a try?
