Unable to Flash Terrarium in Plugdata
Good evening,
I just built a PedalPCB. i am trying to flash a PD file in Plugdata but I keep getting Export Failed errors. Unfortunately I have no coding experience so I can not make anything of it. The link to the file is here.
--> Generating C
  1) e[91mErrore[0m pd2hv:  in "" @ (x:0, y:0): Don't know how to parse object "hv.freqshift~". Is it an object supported by Heavy? Is it an abstraction? Have the search paths been correctly configured?
  2) e[91mErrore[0m pd2hv:  in "" @ (x:0, y:0): Don't know how to parse object "hv.vline~". Is it an object supported by Heavy? Is it an abstraction? Have the search paths been correctly configured?
  3) e[91mErrore[0m pd2hv:  in "" @ (x:0, y:0): There was an error while connecting two objects. Have all objects been correctly instantiated? Have all inlets and outlets been declared?
  4) e[91mErrore[0m pd2hv:  in "" @ (x:0, y:0): There was an error while connecting two objects. Have all objects been correctly instantiated? Have all inlets and outlets been declared?
  5) e[91mErrore[0m pd2hv: [comment null object placeholder (hv.freqshift~)] in "" @ (x:0, y:0): Connection made to non-existent inlet at [comment {'text': 'null object placeholder (hv.freqshift~)'}]:0.
  6) e[91mErrore[0m pd2hv: [comment null object placeholder (hv.freqshift~)] in "" @ (x:0, y:0): Connection made to non-existent inlet at [comment {'text': 'null object placeholder (hv.freqshift~)'}]:1.
  7) e[91mErrore[0m pd2hv: [comment null object placeholder (hv.freqshift~)] in "" @ (x:0, y:0): Connection made to non-existent inlet at [comment {'text': 'null object placeholder (hv.freqshift~)'}]:1.
  8) e[91mErrore[0m pd2hv: [comment null object placeholder (hv.vline~)] in "" @ (x:0, y:0): Connection made to non-existent inlet at [comment {'text': 'null object placeholder (hv.vline~)'}]:0.
Total compile time: 2226.56ms
Compiling for custom...
make: C:/Users/paule/AppData/Local/Temp/Heavy-9d439989d70b567b2d7b2d/daisy/source/Makefile: No such file or directory
make: *** No rule to make target 'C:/Users/paule/AppData/Local/Temp/Heavy-9d439989d70b567b2d7b2d/daisy/source/Makefile'.  Stop.
I don’t have a Terrarium, but those files (.pd and .json) produced source code and binary file successfully on my system.
These objects are from Heavylib, which is included in plugdata.
However there is a known problem with the plugin version that the PATH isn’t correctly read+set.
So I suspect you are using the plugin version to flash your Terrarium. Please try the standalone version of plugdata instead.
This is fixed in the latest nightly builds of the plugin version, btw.
2 posts were split to a new topic: Error: c2daisy: Expecting ‘,’ delimiter
