Hi! I’ve been searching in the forum and this problem seems to happen to many of PD users.
I’m trying to upload a very basic oscillator program in PD to DaisyPatch, and I simply can’t.
It always gives an error in the end:
Downloading element to address = 0x08000000, size = 91288
Erase [=========================] 100% 91288 bytes
Erase done.
Download [=========================] 100% 91288 bytes
Download done.
File downloaded successfully
Submitting leave request…
If I use the Web Programmer I can upload all the provided examples.
In the past I was able to upload PD patches using Pd2DSY and also with Plugdata.
But suddently I can’t do it anymore.
What are you experiencing (audio-wise) when you reset the daisy after seeing the error? Or are you resetting???
If you’re still stuck can you upload the patch here and-or use one of the examples in PD format and try plugdata and-or pd2dsy and upload the output here and report what the results are on the daisy from an audio standpoint.
This error is expected and can be ignored. It is indeed a bit confusing, but there is not really a good way to ignore this part of the dfu-util execution.
As @tunagenes said did you test the resulting program? It should actually work when you run your unit.
