I am trying to add some new functions to the Daisy OLED Driver/Library.
Right now there is no support for Bitmaps and I would like to add that.
I am pulling my hair out trying to figure out where to add it.
I tried adding it after the DrawPixel function in dev/oled_ssd130x.h but i just get errors in my main program saying it can not find the function.
i wonder if instead I should be adding it to
display.h or oled_display.h??
I keep wondering if Part of the issue is that oled_ssd130x.h uses a template class and I would need to add another header file for my function but I am not even sure if dev/oled_ssd130x.h is the right place to add the additional function.
here is the function
/* Draw a bitmap */
void DrawBitmap(uint8_t x, uint8_t y, const unsigned char* bitmap, uint8_t w, uint8_t h, bool on) {
int16_t byteWidth = (w + 7) / 8; // Bitmap scanline pad = whole byte
uint8_t byte = 0;
if (x >= SSD1306_WIDTH || y >= SSD1306_HEIGHT) {
return;
for (uint8_t j = 0; j < h; j++, y++) {
for (uint8_t i = 0; i < w; i++) {
if (i & 7) {
byte <<= 1;
} else {
byte = (*(const unsigned char *)(&bitmap[j * byteWidth + i / 8]));
if (byte & 0x80) {
DrawPixel(x + i, y, on);
return;
thanks for any help
here is some additional info on how CUBEMX drivers do it
for reference here are two other stm32 Oled Libraries I am trying to grab functions from or use to enhance/replace the daisy oled_ssd130x.h template class
UG82 stm32
[https://github.com/afiskon/stm32-ssd1306/blob/7e0c25d90250630b51202f5079f75e7b59d732f8/ssd1306/ssd1306.h#L61](https://stm32 Oled Library )
my issue here is a conceptual one. I do not understand how to apply the cubeIDE style drivers which call HAL libraries to the Daisy Framework. If this was a Cube Project I would just add the headers and the files etc but as Daisy uses Intermediate Template classes etc I am getting stuck — even if I was to ditch the Daisy display drivers I am still confused as to whether or not I could use the HAL commands.
- in the u8g2 library all the calls are HAL GPIO pins and the SPI TYPEDEF HSPI
I CAN FIND HSPI in the daisy folder CUBE/DAISY_SEED_REV4/INC
But I cant find any other references to it being used. This is the problem I always end up having. Coming from a CUBEMX background, I do not understand how to make STM32 drivers work with the DaisyLib when most of the systems do not use the same names as the Cube Names.
void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
GPIO_InitTypeDef GPIO_InitStruct;
if(hspi->Instance==SPI2)
/* USER CODE BEGIN SPI2_MspInit 0 */
/* USER CODE END SPI2_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_SPI2_CLK_ENABLE();
/**SPI2 GPIO Configuration
PB13 ------> SPI2_SCK
PB15 ------> SPI2_MOSI
GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* USER CODE BEGIN SPI2_MspInit 1 */
/* USER CODE END SPI2_MspInit 1 */
In the other STM32 driver there are DEFINES for the ports and addresses. but I am not sure If i need to use the TRANSPORT CONFIG?
// I2C Configuration
#define SSD1306_I2C_PORT hi2c1
#define SSD1306_I2C_ADDR (0x3C << 1)
// SPI Configuration
//#define SSD1306_SPI_PORT hspi1
//#define SSD1306_CS_Port OLED_CS_GPIO_Port
//#define SSD1306_CS_Pin OLED_CS_Pin
//#define SSD1306_DC_Port OLED_DC_GPIO_Port
//#define SSD1306_DC_Pin OLED_DC_Pin
//#define SSD1306_Reset_Port OLED_Res_GPIO_Port
//#define SSD1306_Reset_Pin OLED_Res_Pin
AND it also calls the I2C typedef
void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
if(hi2c->Instance==I2C1)
/* USER CODE BEGIN I2C1_MspInit 0 */
/* USER CODE END I2C1_MspInit 0 */
/**I2C1 GPIO Configuration
PB8 ------> I2C1_SCL
PB9 ------> I2C1_SDA
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
__HAL_RCC_I2C1_CLK_ENABLE();
/* USER CODE BEGIN I2C1_MspInit 1 */
/* USER CODE END I2C1_MspInit 1 */
void HAL_I2C_MspDeInit(I2C_HandleTypeDef* hi2c)
/* USER CODE BEGIN I2C1_MspDeInit 0 */
/* USER CODE END I2C1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_I2C1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_8|GPIO_PIN_9);
/* USER CODE BEGIN I2C1_MspDeInit 1 */
/* USER CODE END I2C1_MspDeInit 1 */
Good News
I figured it out!
Adding this function toward the BOTTOM of Display.H (in daisy SRC)
void DrawMyBitmap(uint_fast8_t x,uint_fast8_t y,const uint8_t* bitmap,uint_fast8_t w,uint_fast8_t h, bool on)
uint_fast8_t byteWidth = (w + 7) / 8; // Bitmap scanline pad = whole byte
uint8_t byte = 0;
for (uint_fast8_t j = 0; j < h; j++, y++) {
for (uint_fast8_t i = 0; i < w; i++) {
if (i & 7)
byte <<= 1;
else
byte = bitmap[j * byteWidth + i / 8];
if (byte & 0x80)
((ChildType*)(this))->ChildType::DrawPixel(x + i, y, on);
allows for calling a bitmap from your main file
patch.display.DrawMyBitmap(0, 0, github_logo_64x64, 64, 64, true);
