How to trigger the ADSR example via Midi?
Hi Philoop,
What’s your electronics setup looking like? Do have the Daisy Seed with a TRS MIDI setup similar to the Pod? If so, I would recommend first trying out the Midi.ino example in the Pod example to make sure that your circuit is hooked up correctly before coding.
It is wired as the Pod, Hardware midi. I tested the Pod example, but it Triggers the Adenv with
void handleNoteOn(byte inChannel, byte inNote, byte inVelocity) {
env.Trigger();
osc.SetFreq(mtof(inNote));
I don`t understand how to trigger the ADSR.
Now i understand
// Title: adsr
// Description: Triangle wave controlled by adsr envelope
// Hardware: Daisy Seed
// Author: Ben Sergentanis
#include "DaisyDuino.h"
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#include <MIDI.h>
DaisyHardware hw;
size_t num_channels;
Adsr env;
Oscillator osc;
Metro tick;
bool gate;
byte note;
float osc_out, env_out, ea;
// When the metro ticks, trigger the envelope to start.
/*if (tick.Process()) {
gate = !gate;
// Use envelope to control the amplitude of the oscillator.
env_out = env.Process(gate);
osc.SetAmp(env_out);
osc_out = osc.Process();
out[chn][i] = osc_out;
void setup() {
float samplerate;
samplerate = DAISY.get_samplerate();
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.turnThruOff();
MIDI.setHandleNoteOn(handleNoteOn);
MIDI.setHandleNoteOff(handleNoteOff);
Serial.begin(9600);
env.Init(samplerate);
osc.Init(samplerate);
// Set up metro to pulse every second
tick.Init(1.0f, samplerate);
// Set envelope parameters
env.SetTime(ADSR_SEG_ATTACK, .1);
env.SetTime(ADSR_SEG_DECAY, .1);
env.SetTime(ADSR_SEG_RELEASE, .01);
env.SetSustainLevel(.25);
osc.SetFreq(220);
osc.SetAmp(0.25);
DAISY.begin(MyCallback);
gate = 1;
// env.Retrigger(gate);
Serial.print(inChannel);
Serial.print("t");
Serial.print(inNote);
Serial.print("t");
Serial.println(inVelocity);
void handleNoteOff(byte inChannel, byte inNote, byte offVelocity) {
gate = 0;
void loop() {
MIDI.read();
Serial.println(gate);
Now that i got it working, i would expect a short click,
using these settings:
env.SetTime(ADSR_SEG_ATTACK, .0);
env.SetTime(ADSR_SEG_DECAY, .01);
env.SetTime(ADSR_SEG_RELEASE, .00);
env.SetSustainLevel(.0);
but I get a tone as long as the notelength. hm.
This is because you are not clearing ‘gate’ until Note Off.
To trigger the ADSR, you need to call Process() only once with gate set to 1.
Instead of
Try this:
if(gate) gate = 0;
That triggers the Adsr,(and clicks) but i am losing the gate/sustain then.
Sorry, I misread your problem. Ill give it a try later…
I’d suggest trying some different values, the fast attack makes it hard to discern the decay to sustain level. Maybe
Attack 1.0f
Decay 1.0f
Sustain 0.5f
Release 0.f
This way, you should see a 1 second rise to max level, a 1 second decay to 1/2 level, and a quick release when key is released.
I was using the tick example, there i couldnt get a click.My Midi example is working fine. Sorry for the noise. ![]()
I added glide from https://github.com/treisti/303duino/blob/master/_303/_303.ino
// Title: adsr
// Added glide from https://github.com/treisti/303duino/blob/master/_303/_303.ino
#include <MIDI.h>
byte legato_mode = 3; // off / on / glide / legato+glide
byte master_channel = 1;
int glide_range = 10000;
byte current_note = 0;
byte previous_note = 0;
int glide_step = 0;
DaisyHardware hw;
Adsr env;
Oscillator osc;
bool gate;
int freq;
//if(gate) gate = 0; // tigger env instead of gate
updateFrequency(glide_range);
void setup() {
float samplerate;
MIDI.turnThruOff();
Serial.begin(9600);
env.SetTime(ADSR_SEG_RELEASE, .1);
osc.SetFreq(220);
osc.SetAmp(0.25);
if(inChannel == master_channel) {
if(!current_note) {
gate = 1;
} else if(legato_mode == 0 || legato_mode == 2) {
gate = 1;
previous_note = current_note;
current_note = inNote;
if(previous_note) {
glide_step = 0;
Serial.print("t");
Serial.print("t");
if(inChannel == master_channel && current_note == inNote) {
previous_note = 0;
current_note = 0;
gate = 0;
void updateFrequency(int glide_range) {
float freq = mtof(current_note-12) ;
if(previous_note && legato_mode >= 2 && glide_step < glide_range) {
float previous_freq = mtof(previous_note-12);
freq = previous_freq + glide_step * (freq - previous_freq) / glide_range;
glide_step ++;
osc.SetFreq(freq);
void loop() {
MIDI.read();
Serial.println(freq);
I have set the glide_range to 10000. But what are 10000 in ms ?
