Hi I was trying to install the Diasy toolchain but my installer stops responding when I click agree to the license so I tried to manually install the toolchain by running the install.command file where I get:
Installing DaisyToolchain
Updating Homebrew
==> Updating Homebrew...
Already up-to-date.
Installing packages with Homebrew
Warning: open-ocd 0.12.0_1 is already installed and up-to-date.
To reinstall 0.12.0_1, run:
brew reinstall open-ocd
Warning: dfu-util 0.11 is already installed and up-to-date.
To reinstall 0.11, run:
brew reinstall dfu-util
Warning: Not upgrading gcc-arm-embedded, the latest version is already installed
find: /usr/local/Caskroom/gcc-arm-embedded: No such file or directory
Done
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
but when I open the blink example and run task build_all on vscode I get:
* Executing task: make
arm-none-eabi-g++ -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -DSTM32H750xx -ISource -ISource/Control -ISource/Drums -ISource/Dynamics -ISource/Effects -ISource/Filters -ISource/Noise -ISource/PhysicalModeling -ISource/Synthesis -ISource/Utility -O3 -Wall -Werror -fdata-sections -ffunction-sections -MMD -MP -MF"build/adenv.d" -MT"build/adenv.d" -fno-exceptions -finline-functions -std=gnu++14 -static -Wa,-a,-ad,-alms=build/adenv.lst Source/Control/adenv.cpp -o build/adenv.o
/bin/sh: arm-none-eabi-g++: command not found
make: *** [build/adenv.o] Error 127
* The terminal process "/bin/zsh '-l', '-c', 'make'" failed to launch (exit code: 2).
* Terminal will be reused by tasks, press any key to close it.
I’m on a 2023 MacBook pro with M2 pro and macOS Sonoma 14.3.1, does anyone know what might help?
