has anyone tried to use the variable delay “vd~” ?
I have successfully used the item “delread~” but failed to use “vd~”.
there must be some problem…
Did you try delread4~?
Vd~ is a 4 point interpolated delay and so is the delread4~.
Both vd~ and delread4~ does audio rate modulation.
Delread~ is not interpolated and does not do audio rate modulation.
As far as I know vd~ and delread4~ are pretty much the same, I think vd~ is an old name. So I would try delread4~ instead of vd~
Unfortunately delread cannot be used, the object is not supported by Heavy.
I found this list, delread~ seems to be supported but delread4~ not:
So yeah VD~ is the best solution of you need to modulate the delay. So not sure what is wrong here, since vd~should be supported. I can’t check the code myself, I am not that code savy.
thank you. Let’s see if other users can help us. The vd~ object is very important, without that pure data is very limited
Agree fully, a delay that can be modulated is very important for so many things, delay chorus flanger etc.
Guess we have to wait a bit and see where it goes, the script
So I wasn’t able to recreate your issues with [vd~] not working, but I made the Petal test example use it so that people can have a working patch to use as a starting point or mess with.
There were a few oddities where you need to make sure that you’re sending a signal to the inlet (you can patch the knob through a [line~] object (and also pack it with a second value so you can smooth out the changes a bit otherwise the delay line will click a lot while changing the knobs).
Ok, thanks @shensley
