HI everyone, I’m just starting out with the Daisy Seed and VS Code so please forgive me for asking some questions that are probably quite simple. I’ve think I’ve installed the toolchain correctly and the examples folder in on my desktop following on the instructions online but try as I may I can not get the blink program to compile, all I get is errors. below is the output I get. could someone have a look and if possible let me know what I may have done wrong and how it can be fixed. Thanks for reading and I hope someone can help… I’m running windows 10
Executing task: make clean; make; make program-dfu
Please report bugs to dfu-util / Tickets
No such file or directory: Could not open file build/Blink.bin for reading
make: *** […/…/libDaisy/core/Makefile:330: program-dfu] Error 74
The terminal process “C:\Program Files\Git\bin\bash.exe ‘–login’, ‘-i’, ‘-c’, ‘make clean; make; make program-dfu’” terminated with exit code: 2.
Terminal will be reused by tasks, press any key to close it.
Of course, I could be wrong. My reasoning is that those error messages indicate that your version of GCC doesn’t have support for Cortex-M7, which has been around for years.
Where did you get instructions on installing the toolchain? This shouldn’t be a research project or an adventure.
Dmax7@DESKTOP-72DADD4 MINGW64 ~/Documents/Daisy_Seed_Projects/DaisyExamples/seed/Blink (master)
$ g++ --version
g++.exe (GNU Arm Embedded Toolchain 10-2020-q4-major) 10.2.1 20201103 (release)
I take it this is the correct version ?
Well Im still trying to get this working … can no one tellme why Im getting these errors ? ive looked for answers on the forum here but cant find anything that works ? it seems that no matter what I do I can not get the Make command to work ?
please help if you can
I’m not a windows guy, so this might be a red herring, but are you sure that g++.exe and arm-none-eabi-g++.exe are the same program? What does arm-none-eabi-g++.exe --version show?
