Hello! I am just getting started with the Patch Submodule and the patch.Init() but I can’t get my PC to detect the module when I connect it through USB. Am I missing an extra driver or something?
I’ve had success in building modules around the Daisy Seed using the same machine and Arduino IDE, so this seems to be a Patch SM-related issue.
I’m on Debian 11.
Summary of my system in case it helps:
H/W path Device Class Description
system System Product Name (SKU)
/0 bus ProArt Z490-CREATOR 10G
/0/0 memory 64KiB BIOS
/0/3f memory 64GiB System Memory
/0/3f/0 memory 16GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/3f/1 memory 16GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/3f/2 memory 16GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/3f/3 memory 16GiB DIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/4e memory 640KiB L1 cache
/0/4f memory 2560KiB L2 cache
/0/50 memory 20MiB L3 cache
/0/51 processor Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
/0/100 bridge Intel Corporation
/0/100/1 bridge 6th-10th Gen Core Processor PCIe Controller (x16)
/0/100/1/0 display GP107 [GeForce GTX 1050 Ti]
/0/100/1/0.1 multimedia GP107GL High Definition Audio Controller
/0/100/14 bus Comet Lake USB 3.1 xHCI Host Controller
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/2 bus 4-Port USB 2.0 Hub
/0/100/14/0/2/1 bus 4-Port USB 2.0 Hub
/0/100/14/0/2/1/3 input USB-HID Keyboard
/0/100/14/0/2/1/4 input 2.4G Wireless Device
/0/100/14/0/2/4 input USB Receiver
/0/100/14/0/3 input Tablet Monitor
/0/100/14/0/5 multimedia Scarlett 2i2 USB
/0/100/14/0/6 multimedia C922 Pro Stream Webcam
/0/100/14/0/b bus USB2.0 Hub
/0/100/14/0/c input AURA LED Controller
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14/1/1 scsi6 storage External USB 3.0
/0/100/14/1/1/0.0.0 /dev/sdf volume 1863GiB nal USB 3.0
/0/100/14/1/2 bus 4-Port USB 3.0 Hub
/0/100/14/1/2/1 bus 4-Port USB 3.0 Hub
/0/100/14/1/2/1/1 scsi7 storage USB3.0 Card Reader
/0/100/14/1/2/1/1/0.0.0 /dev/sdg disk MassStorageClass
/0/100/14/1/2/1/1/0.0.0/0 /dev/sdg disk
/0/100/14/1/2/1/1/0.0.1 /dev/sdh disk MassStorageClass
/0/100/14/1/2/1/1/0.0.1/0 /dev/sdh disk
/0/100/14.2 memory RAM memory
/0/100/15 bus Comet Lake PCH Serial IO I2C Controller #0
/0/100/15.1 bus Comet Lake PCH Serial IO I2C Controller #1
/0/100/16 communication Comet Lake HECI Controller
/0/100/17 scsi0 storage Intel Corporation
/0/100/17/0 /dev/sda disk 250GB WDC WDS250G2B0A
/0/100/17/0/1 /dev/sda1 volume 15MiB reserved partition
/0/100/17/0/2 /dev/sda2 volume 232GiB Windows NTFS volume
/0/100/17/1 /dev/sdb disk 2TB WDC WD20EZRZ-00Z
/0/100/17/1/1 /dev/sdb1 volume 1863GiB OS X ZFS partition or Solaris /usr partition
/0/100/17/1/9 /dev/sdb9 volume 8191KiB reserved partition
/0/100/17/2 /dev/sdc disk 2TB WDC WD20EZRZ-00Z
/0/100/17/2/1 /dev/sdc1 volume 1863GiB OS X ZFS partition or Solaris /usr partition
/0/100/17/2/9 /dev/sdc9 volume 8191KiB reserved partition
/0/100/17/3 /dev/sdd disk 2TB WDC WD20EZAZ-00L
/0/100/17/3/1 /dev/sdd1 volume 1863GiB OS X ZFS partition or Solaris /usr partition
/0/100/17/3/9 /dev/sdd9 volume 8191KiB reserved partition
/0/100/17/0.0.0 /dev/sde disk 2TB WDC WD20EZAZ-00L
/0/100/17/0.0.0/1 /dev/sde1 volume 1863GiB OS X ZFS partition or Solaris /usr partition
/0/100/17/0.0.0/9 /dev/sde9 volume 8191KiB reserved partition
/0/100/1b bridge Comet Lake PCI Express Root Port #17
/0/100/1b.4 bridge Comet Lake PCI Express Root Port #21
/0/100/1b.4/0 enp3s0 network AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
/0/100/1c bridge Intel Corporation
/0/100/1c.4 bridge Intel Corporation
/0/100/1c.4/0 enp5s0 network Ethernet Controller I225-V
/0/100/1c.6 bridge Intel Corporation
/0/100/1c.6/0 enp6s0 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/1d bridge Comet Lake PCI Express Root Port #9
/0/100/1d/0 storage NVMe SSD Controller SM981/PM981/PM983
/0/100/1f bridge Intel Corporation
/0/100/1f.3 multimedia Comet Lake PCH cAVS
/0/100/1f.4 bus Comet Lake PCH SMBus Controller
/0/100/1f.5 bus Comet Lake PCH SPI Controller
/0/1 system PnP device PNP0c02
/0/2 system PnP device PNP0c02
/0/3 communication PnP device PNP0501
/0/4 system PnP device PNP0c02
/0/5 generic PnP device INT3f0d
/0/6 system PnP device PNP0c02
/0/7 system PnP device PNP0c02
/0/8 system PnP device PNP0c02
/0/9 system PnP device PNP0c02
/1 power To Be Filled By O.E.M.
/2 br-5ab861724475 network Ethernet interface
/3 docker0 network Ethernet interface
(EDIT 1): I have tried it on the USB hub as well as the other ports on my PC directly, but still no success.
