Hi all,
After a bit of time I am still having trouble with getting the web programmer to work. Here is what I am observing:
- When the Daisy device is in the “normal” (non boot mode) I get this option: “Daisy Seed Built In - Paired”
- When I reset in boot mode, the only item I see that may be the Daisy device is labeled as: “USB Device - Paired”
Could it be my DFU install/path setup???
I did unzip DFU.
I set the path to add in the location of DFU in Windows
Note: I added both the DFU location and the DFU\win64 location because I am on a 64bit system.
Note: My goal is to have this device running the Oopsy setup as I have some code i’ve created in MAX/MSP Gen that I would like to load onto the device and see what may or may not be working.
Any thoughts, ideas, or help here would be much appreciated.
Thanks,
Brett
