I just got a Segger J-Link Mini. I’m not having any luck programming the Daisy with it so far. I’m running macOS 10.14.6. I’m not sure what else to try. Is there a step I’ve missed?
- I can program the Daisy directly through
build_and_program_dfu. - I’ve downloaded and installed the driver from Segger’s website.
- I’ve installed the Cortex-Debug VS Code extension.
- The Daisy is powered from its USB port.
- The J-Link is connected to a USB port on the Mac and its green LED is on.
- The J-Link is connected to the Daisy. I’m pretty sure the cable is oriented correctly (see photo).
- The output from
make programis:
openocd -s /usr/local/share/openocd/scripts -f interface/stlink.cfg -f target/stm32h7x.cfg \
-c "program ./build/Blink.elf verify reset exit"
Open On-Chip Debugger 0.11.0
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1800 kHz
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
make: *** [program] Error 1
