I’ve been playing with my standalone Daisy seed and Pod. I have a patch.Init() and decided to put that into my case, but then I discovered that the reset and boot pins are basically inaccessible. I thought to use the STLink, but then I discovered the JTAG needs to be soldered on. So I have a couple of questions:
- What is the best way to remove the patch submodule? It seems to not want to budge
I don’t want to break the PCB. Any suggestions how how to separate the boards? - I suspect the normal way to solder the header is to have the pins face the same way as the other headers, but I assume I can solder the header on the other side of the board as well. I wasn’t sure too whether the JTAG cable connector would fit with the board re-inserted.
- I’ve not soldered headers with that pitch. Any suggestions on how to do this.
I ordered my patch.Init() at the end of Aug. 2022, and right now it says the JTAG is included, but I don’t see it in the box. That isn’t to say that I didn’t lose when I looked at it last year, especially if it was just loose in the box and not in a little bag.
