I really want to get this to work but I keep getting errors when I try to compile the file.
➜ daisySP git:(master) ✗ g++ ./hello/daisy_sine.cpp -o ./hello/daisy_sine -I./Source -L./build -ldaisysp # compile
In file included from ./hello/daisy_sine.cpp:3:
In file included from ./Source/daisysp.h:20:
./Source/Control/adsr.h:90:13: error: function definition does not declare parameters
float sus_level\_{0.f};
./Source/Control/adsr.h:91:13: error: function definition does not declare parameters
float x\_{0.f};
./Source/Control/adsr.h:92:13: error: function definition does not declare parameters
float attackShape\_{-1.f};
./Source/Control/adsr.h:93:13: error: function definition does not declare parameters
float attackTarget\_{0.0f};
./Source/Control/adsr.h:94:13: error: function definition does not declare parameters
float attackTime\_{-1.0f};
./Source/Control/adsr.h:95:13: error: function definition does not declare parameters
float decayTime\_{-1.0f};
./Source/Control/adsr.h:96:13: error: function definition does not declare parameters
float releaseTime\_{-1.0f};
./Source/Control/adsr.h:97:13: error: function definition does not declare parameters
float attackD0\_{0.f};
./Source/Control/adsr.h:98:13: error: function definition does not declare parameters
float decayD0\_{0.f};
./Source/Control/adsr.h:99:13: error: function definition does not declare parameters
float releaseD0\_{0.f};
./Source/Control/adsr.h:101:13: error: function definition does not declare parameters
uint8_t mode\_{ADSR_SEG_IDLE};
./Source/Control/adsr.h:102:13: error: function definition does not declare parameters
bool gate\_{false};
./Source/Control/adsr.h:78:9: error: use of undeclared identifier ‘sus_level_’; did you mean ‘sus_level’?
sus_level\_ = sus_level;
sus_level
./Source/Control/adsr.h:74:39: note: ‘sus_level’ declared here
inline void SetSustainLevel(float sus_level)
./Source/Control/adsr.h:83:49: error: use of undeclared identifier ‘mode_’
inline uint8_t GetCurrentSegment() { return mode\_; }
./Source/Control/adsr.h:87:44: error: use of undeclared identifier ‘mode_’
inline bool IsRunning() const { return mode\_ != ADSR_SEG_IDLE; }
In file included from ./Source/daisysp.h:24:
In file included from ./Source/Drums/analogbassdrum.h:16:
In file included from ./Source/Synthesis/oscillator.h:13:
./Source/Utility/dsp.h:32:8: error: unknown type name ‘constexpr’
static constexpr float kRandFrac = 1.f / (float)RAND_MAX;
./Source/Utility/dsp.h:35:8: error: unknown type name ‘constexpr’
static constexpr float kOneTwelfth = 1.f / 12.f;
./Source/Utility/dsp.h:157:6: warning: scoped enumerations are a C++11 extension [-Wc++11-extensions]
enum class Mapping
./Source/Utility/dsp.h:177:54: warning: use of enumeration in a nested name specifier is a C++11 extension [-Wc++11-extensions]
fmap(float in, float min, float max, Mapping curve = Mapping::LINEAR)
./Source/Utility/dsp.h:181:14: warning: use of enumeration in a nested name specifier is a C++11 extension [-Wc++11-extensions]
case Mapping::EXP:
./Source/Utility/dsp.h:181:14: error: integral constant expression must have integral or unscoped enumeration type, not ‘daisysp::Mapping’
case Mapping::EXP:
./Source/Utility/dsp.h:183:14: warning: use of enumeration in a nested name specifier is a C++11 extension [-Wc++11-extensions]
case Mapping::LOG:
./Source/Utility/dsp.h:183:14: error: integral constant expression must have integral or unscoped enumeration type, not ‘daisysp::Mapping’
case Mapping::LOG:
./Source/Utility/dsp.h:188:14: warning: use of enumeration in a nested name specifier is a C++11 extension [-Wc++11-extensions]
case Mapping::LINEAR:
fatal error: too many errors emitted, stopping now [-ferror-limit=]
