I am currently trying to set sampling rate to 96 kHz but seems like the internal sampling rate is still the default 48kHz. I currently have a simple arduino script where I have a microphone connected to in[0] and running peak frequency detection.
The correct peak frequency is only achieved when sampling_rate is set to 48000. Even when I change
hw = DAISY.init(DAISY_SEED, AUDIO_SR_96K);
to
or
hw = DAISY.init(DAISY_SEED, AUDIO_SR_32K);
there is no change in behavior. Why so? I followed the installation tutorials. Am I missing anything? This is the code.
// Import libraries
#include "DaisyDuino.h"
#include "arduinoFFT.h"
// Daisy Hardware object
DaisyHardware hw;
const float multiplier = 10000;
// FFT object and parameters
const uint16_t samples = 1024;
const float sample_rate = 48000;
float vReal[samples];
float vImag[samples];
ArduinoFFT<float> FFT = ArduinoFFT<float>(vReal, vImag, samples, sample_rate);
// Variables for FFT processing
float fft_input_buffer[samples];
int fft_buffer_index = 0;
volatile float mic_level = 0.0f;
volatile float peak_frequency = 0.0f;
volatile float system_sr = 0.0f;
// Audio callback function
float sum_of_squares = 0.0f;
// Collect samples
float sample = in[0][i];
sum_of_squares += sample * sample;
// If our FFT buffer has space, add the current sample to it
if (fft_buffer_index < samples) {
fft_input_buffer[fft_buffer_index] = sample;
fft_buffer_index++;
// Calculate RMS for volume level
mic_level = sqrtf(sum_of_squares / size + 1e-9) * multiplier;
// Perform FFT
if (fft_buffer_index == samples) {
// Copy the collected float samples into the double array for the FFT library
for(int i = 0; i < samples; i++) {
vReal[i] = fft_input_buffer[i];
vImag[i] = 0.0; // Imaginary part is always 0 for real-world audio
FFT.windowing(FFTWindow::Hamming, FFTDirection::Forward); /* Weigh data */
FFT.compute(FFTDirection::Forward); /* Compute FFT */
FFT.complexToMagnitude(); /* Compute magnitudes */
peak_frequency = FFT.majorPeak();
// Reset the buffer index to start collecting new samples
void setup() {
Serial.begin(9600); // Use a faster baud rate for more data
system_sr = DAISY.get_samplerate();
DAISY.begin(MyCallback); // Start the audio callback
void loop() {
// Print the microphone level and peak frequency from the main loop
Serial.print("System Sampling Rate: " + String(system_sr) + " Hz");
Serial.print(" | Mic Level (RMS): " + String(mic_level));
Serial.println(" | Peak Freq: " + String(peak_frequency) + " Hz");
delay(100);
