I have been trying to use the SD with oopsy, but I can’t make it work
I have my daisy seed connected with the SD card, it has drumLoop.wav on it
On C++ I have tried this settings with WavPlayer.cpp:
With 400khz it works with 1 bit, but does not with 4 bits
With 12.5Mhz it works with 1 bit, but does not with 4 bits (maybe 4 bits is not compatible with those frequencies)
On 25Mhz it works on 4 bits
On 50Mhz it works on 1 bit, but does not with 4 bits (maybe some inductance on one of the 3 bits left)
In Max/MSP, on source/genlib_daisy.h there is this code:
void sdcard_init() {
daisy::SdmmcHandler::Config sdconfig;
sdconfig.Defaults(); // 4-bit, 50MHz
// sdconfig.clock_powersave = false;
sdconfig.speed = daisy::SdmmcHandler::Speed::STANDARD; //this line was commented, I don't know if it works
sdconfig.width = daisy::SdmmcHandler::BusWidth::BITS_4;
handler.Init(sdconfig);
dsy_fatfs_init();
f_mount(&SDFatFS, SDPath, 1);
So, changing speed and width on those lines I have tried:
25Mhz (STANDARD) 4 bits and 1 bit, not working
On default speed (I think it’s FAST=50Mhz) 4 bits and 1 bit, not working
I used the ‘sdcard-minimal.maxpat’ example
