Is it possible to save some basic stuff like parameter settings somewhere on the seed that will then be accessible next time I power up? or would this require an sd card?
Certainly, you can store information in the ‘flash memory’ - both the smaller on chip flash in the STM32H750IBK6 and the larger flash on the Seed, more or less permanently.
Ok great, could you point me in the direction of any documentation on the commands id need? I assume its STM32 stuff rather than in libdaisy right? (i couldnt find anything in the libdaisy documentation)
I might try throw together a quick demonstration for other noobs
Maybe my search could have been more extensive…
Thank you!
That documentation doesn’t provide any guidance for how to actually use the commands.
An example of using the QSPI flash to store/retrieve settings is the Veno-Echo; source code can be found on GitHub.
See also the PersistentStorage Class in libDaisy.
Thank you! will check that now. Sounds like a demonstration might be helpful then. Will try and put something together once i wrap my head around it
Below is the code I use to save/load my synth’s configuration. Make sure you have
USE_FATFS = 1 in your makefile.
bool ByteBeatSynth::LoadParameters()
bool success = false;
size_t byteswritten;
size_t len = sizeof(config_);
// Read back the test file from the SD Card.
if(f_open(&SDFile_, CONFIG_FILE_NAME, FA_READ) == FR_OK)
f_read(&SDFile_, &config_, len, &byteswritten);
f_close(&SDFile_);
success = true;
return success;
bool ByteBeatSynth::SaveParameters()
// initialize config_
// Open and write the test file to the SD Card.
if(f_open(&SDFile_, CONFIG_FILE_NAME, (FA_CREATE_ALWAYS) | (FA_WRITE))
== FR_OK)
f_write(&SDFile_, &config_, len, &byteswritten);
f_close(&SDFile_);
return true;
return false;
I believe that is an example for saving params on SD-Card, and while that certainly makes sense and may be useful, the original question was how to save across boot, without using SD-Card.
You are right, I should have read the OP more carefully.
