Reverb on Oscillator
Hey! I am working on a chord synth, and want to implement reverb.
I have 4 oscillators working.
I’m using this code to mix the Oscillators:
float average = ((saw1 + saw2 + saw3 + saw4) /4);
    output = flt.Process(average);
I’m attempting to add the ReverbSC example to the sketch but cant figure out how to change it from effecting the Daisy Audio inputs, to effecting the internal oscillators I have set up (or alternatively the master output).
ReverbSc verb;
    float out1, out2;
    verb.Process(in[0][i], in[1][i], &out1, &out2);
    out[0][i] = out1;
    out[1][i] = out2;
void setup() {
  float sample_rate;
  verb.Init(sample_rate);
  verb.SetFeedback(0.85f);
  verb.SetLpFreq(18000.0f);
  DAISY.begin(MyCallback);
Any advice would be greatly appreciated :smile:
Should be pretty easy, the only thing is the reverb example is stereo, while your synth is mono:
    float output = flt.Process(average);
    float out1, out2;
    verb.Process(output, output, &out1, &out2);
    out[0][i] = out1;
    out[1][i] = out2;
This worked beautifully. Thank you very much @KnightHill !
