I copied over the bin files to this from the openocd to the bin location in the Daisy tool chain directory (the openocd.exe and the two libs)
I copied over all of the stlink.cfg files from the v0.11.0-5 interface directory and put them into the Daisy tool chain \ scripts \ interface directory.
What I think is missing in the Daisy tool chain version is the updated STLINK.CFG that has the needed ID of 0x3754 (this is missing in the current Daisy tool chain v1.0.0 stlink.cfg)… and I went ahead and used the openocd.exe from that repository just in case it matters.
As a note: I was not able to drop in replace openocd with the v0.12.0, but if I used v0.11.0-5 eveything worked great.
Good to be back up and running… it seems like a pretty quick upate to the Daisy tool chain should get things going for others as well who may also be observing the issue.
The reason I asked about the source for your STLINK is that the two STLINK MINI that I received from Electro-Smith are x0483:x374e, while the STLINK MINI-e I bought from DigiKey is x0483:x3754.
This is dredging up some really old memory - I THINK that the 1st 2 bytes are the manufacturer, and the 2nd are a ‘model number’ that the manufacturer could use as they pleased.
