1- yes. Look at the JSON pile for hints. Yours will be named seed.yournamehere.json, like the bluemchen and versio
2- no, this hasn’t been implemented yet but is theoretically in the works though it seems the Oopsy~ project leads have their hands full elsewhere at the moment.
3- yes, look at the sample example, “simple.maxpat”
4- yes, automagically you can use the encoder (on electro-smith units with an encoder) to switch between as many [gen~] as you can fit. I assume you can switch the encoder program rotate to another switch in a custom JSON though I haven’t tried this
Ok. I have checked the multi_app example with my POD. I flashes and I can listen the first sound but when y move the encoder and push or push switchers, nothing changes. Is it possible to use with POD or besides selecting Pod on menu I should uptoad a custom JSON?
In other words. Is it possible to use multi-app mode in Pod and plain Daisy Seed. Or it only works on Electro Smith modules? do you need an screen in order it works?
I have checking avery basic patch on Max with two gen~ with a cycle object inside with different frequency inside each one. I also have included an Oopsy object. I choose “versio” from menu and it flash correctly and I get sound but I cannot switch between them using the encoder as multi-app.
My question is Oopsy if recognises the encoder or I do have to create a Json telling I am using a encoder?
Is there something special I should do in order this works properly?
