Hello,
I am using the Daisy Field.h/.cpp files to use as a launching point for lighting some LEDs I have on a board I am brining up.
When reading the code for the Daisy Filed it notes:
static constexpr I2CHandle::Config field_led_i2c_config
{{DSY_GPIOB, 8}, {DSY_GPIOB, 9}},
I2CHandle::Config::Speed::I2C_1MHZ};
In this I am wondering why the DSY_GIPOB,8 and DSY_GPIB, 9 are used? In the header there is PIN_I2C_SCL, PIN_I2C_SDA defined but it does not look they are used. Can I use the PIN_I2C in place of the DSY_GPIOB, 8 section?
Also, what is the best way to understand what DSY_GPIOB, 8 maps to?
Thank you for your help,
Brett
