I’m trying to build a standalone Impulse Response loader/player that can take line level input and supply stereo output. I’ve previously programmed stomp boxes using the Daisy Seed on the PedalPCB Terrarium and Cleveland Audio Hothouse platforms, but this is going in a larger enclosure with some other analogue devices.
I considered using the Daisy Pod as my “platform” but it has things I don’t need (like midi and pots and switches that won’t be accessible inside the enclosure) and I’d need to find a way to wire in separate pots and switches mounted to the enclosure. So instead, I ordered the Patch Submodule.
However, I am confused about how to power it. I see it needs +/-12V and can’t run audio off USB only (as I’d originally planned to do). I don’t have space for a separate PSU inside the enclosure, though I could probably fit a small set of components/PCB.
Ideally I’d run it off an isolated “pedal” power supply that can do 500mA cent-negative 12V, 18V or 9V. However, I am not very experienced with electronics and getting very confused about charge pumps, DC-DC converters, and the like.
I’d be grateful for any help! Or, if this is a dead end, some thoughts on whether I could ‘adapt’ the Daisy Seed Pod to run external switches and pots.
Martin
