Possible to make a four track recorder?
Hi!
I’m looking to get a daisy seed (and possibly pod) for a project for my kiddo. I want to make a portable, simplistic four track recorder. I’ve tried this so far with an esp32 audio kit but I’m either hitting the wall of my knowledge, the hardware, or both.
The main requirement is to be able to record one track from the ADC to either SD or RAM, while simultaneously playing up to three other .WAV files (and then write the RAM to disk on stop) with enough low latency that when brought into an NLE they more or less are in sync. Ideally each track could be around 5 minutes.
It seems like it should be, but is this kind of project doable with the Daisy Seed?
hi. what happened with your previous attempt? do you have a basic layout of what things will look like for this project? is the challenge performing the recording?
