Anyone else ever run into a pin having a short to ground? For some reason one of my Seed’s pins (D2) is shorted to ground. Unplugged I have continuity between D2 and GND. I tested on a brand new unused seed and it does not have this. I first noticed this when my pin was no longer producing an output voltage and the Seed was getting very warm. I did all my testing on a barebones sketch and with the Seed only connected to a USB cable. I use this Seed to test new hardware so it’s highly likely I damaged it with all the taking in and out I’ve done with it and possibly I shorted it on my bench somehow. Just wanted to see If anyone else has run into this. Thanks!
