Hello im trying to use persistent storage to store some settings but it keeps freezing my daisy
here’s a basic example I tried to build by looking at the header cause I cant find any other examples on how to implement it.
#include <DaisyDuino.h>
// Define a struct for your settings
struct MySettings {
int myValue;
float anotherValue;
// Add a comparison operator for the PersistentStorage to use
bool operator!=(const MySettings& other) const {
return myValue != other.myValue || anotherValue != other.anotherValue;
// Instantiate QSPIHandle
QSPIHandle qspi;
// Create an instance of PersistentStorage
PersistentStorage<MySettings> storage(qspi);
void setup() {
// Initialize your settings with default values
MySettings defaultSettings = {42, 3.14};
// Initialize PersistentStorage
storage.Init(defaultSettings);
// Load settings into a variable
MySettings currentSettings = storage.GetSettings();
// Modify settings
currentSettings.myValue = 43;
// Save settings
storage.Save();
Try adding delay after GetSettings() and Save()
Hi KnightHill, thanks for the reply, unfortunately it didn’t help. This particular line is making the daisy to freeze it seems.
I suspect you need to initialize qspi before using it. This fragment is from daisy_seed.cpp:
if(memory != System::MemoryRegion::QSPI)
qspi.Init(qspi_config);
Rather than initializing a new qspi handle and passing that to the persistent storage class, you need to pass the qspi handle member of the hardware object you are using (i.e. seed, pod, patch etc…) . qspi is a member of the seed class which is a subclass of the pod/patch/petal (etc…) class.
//Persistent Storage Declaration. Using type Settings and passed the devices qspi handle
PersistentStorage<Settings> SavedSettings(hw.seed.qspi);
I wrote a little guide on using persistent storage here:
Here is an example of using the PersistentStorage class to save parameter values to flash using the daisy Pod. Storing the values in non volatile memory allows them to be accessed between power cycles. This allows for storing presets or settings of knobs used to control multiple parameters
I enjoy making posts like this because not only do I think examples like these are helpful to the less experienced in the community (and also few and far between), but it also helps me to better learn these c…
