I’m new to the Daisy but I have some experience with the Axoloti.
Today i have ported a decimation module I have done on the Axoloti to Daisyduino.
So, I was intrigued to compare the Axoloti (that runs at 168MHz) with the Daisy with the same modules.
I use “micro()” to get the timing, reject erroneous values and get a mean value then i divide the time between two sample block (1/1000 s = 1000us) by the time spent in the function.
Stunningly I obtain very similar performance between the Axoloti and the Daisy. Even when using the O3 option.
I expected a x2 ratio.
Is there some option i need to switch on ?
