PD Array object
I was very sad to see that the Array object in pd is not supported with the daisy seed because it is a very powerful object that I use in almost every patch. Is there any plans to implement it or does anybody knows some alternative ways to get similar functions/sequences in pd?
Thank you
There are no plans to implement [array] however we’re open to pull requests that consider it.
You should be able to get all functionality you are looking for by using [table] though.
I wasn’t aware of the table object, thank you very much.
Please read the documentation for supported objects: Supported Objects - Heavy Compiler Collection
(the version of HVCC supplied with pd2dsy or plugdata might be somewhat outdated compared to these docs)
