patch.Init() range of CV pots
Hi, I am a beginner and puzzled by the results I get from the code below (the range of the CV input seems to be negative):
Measuring the voltage at the respective output I get:
CV_1: min: +0.17V, max: -8.65V
CV_2: min: +0.24V, max: -8.53V
#include "DaisyDuino.h"
DaisyHardware patch;
static void AudioCallback(float**  in, float** out, size_t size)
  float cv_1, cv_2;
  patch.ProcessAnalogControls();
  cv_1 = patch.GetAdcValue(0);
  cv_2 = patch.GetAdcValue(1);
    OUT_L[i] = cv_1;
    OUT_R[i] = cv_2;
void setup() {
  patch = DAISY.init(DAISY_PATCH_SM);
  DAISY.StartAudio(AudioCallback);
void loop() {
I am using the Arduino IDE.
You’re sending the output to the Audio Outputs, which have a range of about -9 to +9v.
They also invert the signal, so +1.0 input produces about -9v output, and -1.0 input produces about +9v output.
I don’t consider it a bug, just a detail that needs to be considered, it’s discussed in the following thread:
Thanks very much - this was very helpful!
