Overclocking the daisy
What do you think about it?
I tried 560mhz and even 600mhz.
While I noticed not much of a difference,
does it work this way and are there side effects?
        enum class SysClkFreq
            FREQ_400MHZ,
            FREQ_560MHZ,
        /** Method to call on the struct to set to defaults
         ** CPU Freq set to 400MHz
         ** Cache Enabled
        void Defaults()
            cpu_freq    = SysClkFreq::FREQ_400MHZ;
            use_dcache  = true;
            use_icache  = true;
            skip_clocks = false;
        /** Method to call on the struct to set to boost mode:
         ** CPU Freq set to 480MHz
         ** Cache Enabled
        void Boost()
            cpu_freq    = SysClkFreq::FREQ_560MHZ;
            use_dcache  = true;
            use_icache  = true;
That won’t change the frequency.
I am also curious about this. How can this be achieved and what are save margins to clock the daisy without additional cooling?
