The ‘OUTPUT LEVEL’ control on my Field feels very loose. I haven’t tried pulling the knob off or opening the Field to look at how it’s mounted. The bottom of the knob is almost flush with the surface of the panel so you can’t see anything beneath. As opposed to the 1-8 knobs which are separated and you can see the mounting nut.
Any advice-instructions? Is this a known problem or just the way it is or broken?
I am still hoping to get an answer from Electro-smith. I am concerned, it feels like the Output Level control is hanging on by a thread. Let me know if I should ask through a different method.
For anyone else similarly curious about this, my Field’s output knob has quite a lot of slack as well.
Apart from that, the knob also causes audible scratching through the output. Any advice for how this could be replaced with something more robust? I am no DIY expert, but this could be a great opportunity to learn
Apologies for reviving this old thread, i understand that the pot being loose is more of a me-issue!
Hey, thanks for identifying the part, much appreciated!
Was able to find some substitutes on Ali Express… not sure if they’ll be any better than Bourns/OEM, but I’ll give them a try and report my findings here
