I recently started to toy with daisy seed and patch submodule and I encountered a problem.
I managed to code a simple sine vco with one CV input for V/Oct and one frequency knob for tuning. To do so I founded the scale and offset value for V/Oct by debugging and using the formula that I found in VoctCalibration class source code.
But since I implemented the V/Oct tracking, the range of the frequency knob is very low : from 8hz to around 250hz. Is there any solution to increase this range ?
I must mention that the V/Oct CV input and the frequency knob are connected to the same ADC (CV_1). I can’t really change this design because I work on an already existent module which include patch submodule (the module is Sibilla by Clatters).
Here is my code :
#include "daisy_patch_sm.h"
#include "daisysp.h"
using namespace patch_sm;
DaisyPatchSM patch;
Oscillator osc;
VoctCalibration calibrator;
size_t size)
calibrator.Record(0.113, 0.378); // 1v and 3v value retrieved via COM debugging
patch.ProcessAllControls();
float climb_knob = patch.GetAdcValue(CV_1);
float freq = mtof(calibrator.ProcessInput(climb_knob));
osc.SetFreq(freq);
float sig = osc.Process();
OUT_L[i] = sig;
OUT_R[i] = sig;
patch.Init();
osc.Init(patch.AudioSampleRate());
while(1) {}
It is added to the voltage given by the knob, the V/Oct tracking on CV input works really well by the way.
The only problem is that the frequency range of the knob is really small, even padded with 30 midi notes I only have a range from about ~50hz to ~1400hz.
During testing and debugging I founded that without any voltage to CV input and the knob fully turned clockwise the maximum value return by patch.GetADCValue(CV_1) is around 0.64.
Maybe the problem is here ?
Sadly it don’t works, as the scale and offset were calculated with VoctCalibration class. This class calculate scale and offset to convert to a midi note
To calibrate the CV input that is used as a V/Oct input. The CV_1 ADC is connected to the CV input and a knob (I can’t change this hardware design as i’m working on already existant module called Sibilla that is using a patch submodule, I’m trying to create a custom firmware on it)
Here i’m trying to go from V/Oct to midi due to the ‘limitation’ of VoctCalibration class, but at the end i need a frequency to feed my oscillator, that is why i use the mtof function that convert a midi note to a frequency.
If there is a method that permit to have a great V/Oct tracking on CV input and a wide range of frequencies on the knob I will use it !
I will try the linear rescaling but as far as i know V/Oct must be exponential, am I wrong ?
1V/octave is NOT linear for frequency. Yes, the voltage goes up in equal steps, but the frequency doesn’t.
It would be helpful to see a schematic of how the CV and pot are wired. If the pot is powered by 5V, and is going into a CV input which is calibrated to 1V/octave, then it is appropriate for the pot to have a 5 octave range.
Ok so I added the linearMap idea float climb_freq = vtof(linearMap(climb_knob, -0.020172, 0.637573, 0, 5)); (those weird floats are the value returned by the ADC when the knob is in min and max position)
The knob have now a much wider range but it begin (at min position) only at aroud D2 (so around 293hz) and the V/Oct deviate from +10cents every octave
Am i missing something ?
Sadly I didn’t have the schematic as I didn’t created this module (Sibilla by Clatters), I searched for it on internet but didn’t find anything. I doubt that the CV input is calibrated for V/Oct as I didn’t see any trimpot on the PCB. There is only 4 Opamps (TL074) a couple of resistors, some capacitors and diodes and of course a patch submodule.
Ah yes you are right I didn’t payed attention to the factor argument !
So it looks like it works, i keep having a difference of 10 cent every octave but that must due to min and max value of the knob, if you have a little bit of time do you have any idea how to have a precise value of the min and max value of the knob ? Is it even possible ?
Is it adding an addition 10 cents for each octave above the base frequency?
Like this?
C1 + 0
C2 +10
C3 +20
Are you using a keyboard or a sequencer as the CV source? Can you output voltages for a number of octaves and check the values against the chart I uploaded?
You can write code to compensate, you will need some data though to look at to see what the pattern is.
Edit: I suppose I’ve been too brief in my responses.
If I’m reading correctly, using the code in the original post, CV tracking was good, but you want more range on the knob. That doesn’t seem feasible, since pot and CV are on the same ADC.
