Hey all! Has anyone made a sampler using Oopsy that can access multiple samples from an SD Card? Trying to figure out how to do that… Especially dealing with different ‘data’ sizes that can be variable to whatever samples you load on the card. Anyone have an example like this? I’m having trouble figuring that out with the included example that only uses one sample with a precalculated data size. Thanks in advance!
best
D
Hello @fadedinstruments!
Unfortunately, it’s not possible atm to use multiple audio files in an SD card for Oopsy.
The workaround that I seen a community member do is preparing multiple samples within a single audio file. If you know the length and position of these samples, you essentially have access to multiple samples even though it’s a single audio file.
