Ahoy all! Quick question on what I might be able to do with switch params inside Gen~… Specifically something like an argument that would return a float representing the number of seconds the switch has been held down?
There’s something like this in the PD integration, but I haven’t been able to find anything like it for Oopsy? In another post, Mr. GrrrWaaa explained things like:
E.g. [param cv1_int_foo @min 0 @max 4] will only ever send 0, 1, 2, 3 or 4.
Also, [param cv2_bool_foo @min 2 @max 5] will only ever be 2 or 5, etc.
Is there more here than just offs and ons?
              Yep, i need this info too! And another question about param modifiers for Encoder on Daisy Patch.
              “Is there more here than just offs and ons?” – yes – if you don’t use “int” or “bool” in the param name, you will get full unquantized floating point resolution. Apologies if I’m misunderstanding the question.
For “the number of seconds the switch has been held down”, there’s a few different ways to approach it – depending on whether this is something you want to know continuously, or only after the button is released, etc. Here’s a patch that shows both of those – you could turn the core of this into an abstraction for re-use:
----------begin_max5_patcher----------
1663.3oc2Z00iahCE84L+Jr30c5Trg.jUpRc+cTsJh.dHtELHrYlosp8295u
f.IPfzDBi1WlLXar84368bu13e9vJqc4ugYVf+F7EvpU+7gUqTEIKXk44UVY
guEkFxTMyhVksCW9aqG008bNkSCyvp59mRRXZcMhFlWwSwb06gLkpKh+8Brd
PsXjDp7k.VOmlGxs.+qokY4w31uobjdNLRUlsorhPdzdBMYaINhq6PmM9OY+
H.gPxefvM5mdxtoiEinpOdptWHwpYe9tu9gMswEi7C0nAQMMU.JBsASxx90C
OH+yi+Og9PdatB5KX1oO7qhwodT332TSaqLLuLGr11F74vHN4EL.1OOBGhG2
ERSNPdCSL9tCwKsnAeqaEd44IIo3KDKDJeJPAZuVAB25+1GTb6EJvlNuTX7x
wkawzvcoZiqa2xZBl969wt639Cm4+lB4DHMvEpImacFNB4H5bboA1FbKbMHo
3WvkLRNsUqWYEVTzp3UsdEIY80bUGE7XSQDptHmlhJwuPpe+CkFVJfHWfupR
sLyad0KpFYhRZEQMUzEJV1LSI0BjTdhUXTNrhYEOIVVp6.qCDmWfxbB5n9IP
aVs1skckvJHIMO5a33VhPh0vBLkPKJwLLkGxM.no5X7ygUo7s8Kozs9iD35V
Yu5rqrRJIw4T4jnyxgr35g6K.nFaqaCFUKngE87xBiCAuLPkLAHqX6BKkqVF
mFTck777ztU07do3m4lpKHT5QrHOuX3JKII6Oy6tKWTY145aUMrsUTcsaEFF
7srvW5x17vzTiqb2t+sPJIKji4D8R.xtoRsvwdVTYdZZG7pq4kdpIVXnGgek
Dy22ITjrFQyIE0FQVMqxwjDLi2sLdXBqaIL920jdqhp1Ybj2xwYEoBTzsABW
DBiy1m+JyzvZCs1DvgjrZ6X2VWrS4mSerqF4m9TSrtgiQzuVYiN3PZgt1AZy
9fmVKzBcNVK7X8PGuilIsDEqKWEYvHyb6YCAFAt.tvdOQrfI0TXCSN1ifdjB
vvM1RzCs2LJ7W+d.9NMvuDmhCY3+XB.E30l.fiS.t2EBHJOKSDpnWFnDmgkY
Xy.BGRPZNMAv2iA6pDJbTvqghxwow.o9EPoF0pSRITbTdEk2VQ9xYs0pXEt5
3fPWnJOBmyvZNKNq8JIME70prB.OG7CrHW5W2io0rFgALlRw2d5xC1lsPAix
VnEmsBihpxpjQB.Z7ekNXNZgFjsNSb6y.d3hCdEhADJfIV7owBSiPgCVovKK
jpJNTDjDyFzPw8Okr706VQKC6qrZ7NGUYu3TElxD4bCrA4kmKF8H3FZqvZfd
imAvwrQP9KcTnchzEmqTR7ZQFNvwBHg7dGDPhg4ZchFw07Fo0aTHZju8DUPP
KeH5DAeXRQgcbbFUFa3XvGmwHNtq04045qRqYs2XgbPnk1iZuXGF4keetbpf
azZqaTLhq6ntU1KMgvdkHPAvdtYDse0ZzXLBbXQWz8gQD6C7Cy1FAM7P8FA8
GkNbWZCjHQ5HI34lOP5T8CFkObVZ9HUBhYiNza4wwWkalyn5GPzcwaYJ6SzD
Y9tscGzFcpKd5SVw0drfOP3Ra57QSN8kxi9ZVSqy3VYxz+bFP1uGNoETc5Ja
M6Ex5ZOy.ae8QnO5IssYwyhS6rbsHFp2UyZ6wxacwOYQ0m5BD8Bbqb6MfOKl
Ahc18YwqOem+p1qvvQAiG0cPNx99vQ+07RDlyIAtd7ChdoyFSJO.UG03UqMX
NfLiz.bTreYodc3yYIiuMvGoPMqj02OovxqJipWKq+N.ftSvXLiSnMecuub3
DykMbRKJW7rXhSB2SZWdYr961hVzIlbSEBqn1MLiDWjSnbyBku5j4cLNDhso
3e5in05ys2Qs4N0S8CV3xBVzIMrev5owgmayS8CG6YANnoZZCclFdfPyNM2z
7z6S7XOrax7X4frmpJh1MYVlDJevoLIpmsyyrvcpTwYDyrW1oVOL4LqyN8oF
5Dg1Y11FNUYwdBkdjLRsxgPtGIO8Nn+gGuqFBSVo28dqjzSrk9mZalSe3KQN
a1lDSUMyavIgoPcIW387KjyKqHW30Y7v00S955MlZ1Fl032iOWm16vbfKxG5
ptkipdra9yZx33UGCkbxpRGkwymkZuj9TGG2ILNnav3flv3.uAiCrsr83tzW
03LFdBNYbzlEGcsNkCwQWmyitJmmdMNG9Jbd702Tc0M66ZaJcKe3WO7e.K9C
6bC
-----------end_max5_patcher-----------
              I very glad to see mr. Grrrwaaa here!
May be you can answer my question about param modifiers for encoder in daisy patch?
Int, bool etc works with main four knobs (cv1-cv4), but when i create more then four params, as you know, i can use encoder and oled screen for them. But all modufiers, such as bool, int not working with it. Only floating numbers. I wanna use encoder for switches, for change some int numbers (for samples, pitches or waves ,for example), but i cant
