Hello. Trouble with Daisy Patch & Oopsy.
I’m trying to flash a complex patch, where there is playback of samples from SD and a separate primitive synthesizer with midi control.
Oopsy gives this error:
sdcard build failed Error: Command failed: arm-none-eabi-g++ build/startup_stm32h750xx.o build/diskio.o build/ff.o build/ff_gen_drv.o build/ccsbcs.o build/sdcard_patch.o -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard --specs=nano.specs --specs=nosys.specs -T…/libdaisy/core/STM32H750IB_flash.lds -L…/libdaisy/build -ldaisy -lc -lm -lnosys -Wl, -Map=build/sdcard.map, --cref -Wl, --gc-sections -Wl, --print-memory-usage -o build/sdcard.elf
compiling…
generated code
I noticed that it appears when using table-based generators (circle, triangle). And also when generating an oscillator using a phase wrap loop (from the gen~ examples). The only option is to generate a sine using ‘accum > sin’. But other strange errors appears: after a while the patch stops correctly detecting the note from MIDI, and over time the whole keyboard plays one note at all.
Also, when using a midi knobs (CC) and simultaneously pressing notes, I get sharp jumps of pitch and strange artifacts.
I am attach a google drive link on .gendsp file.
https://drive.google.com/file/d/1Gyi5ISW7iWohoTXucAFmvMUCjBpr_kpG/view?usp=share_link
